4
[UNIFIED] Op6t battery and heating thread
  1. shiddhi
    Cupcake Jun 12, 2019
    shiddhi , Jun 12, 2019 :
    l kept my phone charging overninght and when i woke up in the morning it is still warm? I haven't noticed that before.
  2. Y1560396438233
    Cupcake Jun 13, 2019
    Ted Olilo likes this.
  3. Ted Olilo
    Ted Olilo , Jun 13, 2019 :
    Just updated my 6T and yes the battery drain is so annoying, it's the first time its happening.I used to enjoy nearly 48 hours of battery life, and now it's half that. What can we do?
  4. B1560311346444
    Cupcake Jun 14, 2019
  5. Meekaran
    Meekaran , Jun 14, 2019 :
    whenever my OnePlus 6t is on charge it heats up a lot .. there is no additional cover on it that's why I can't understand why it happens ... it's been a month that this issue has occurred
  6. drl431
    Marshmallow Jun 14, 2019
    drl431 , Jun 14, 2019 :
    All phone heat up during while charging. Maybe more so now as summer approaches.
    Meekaran likes this.
  7. Meekaran
    yaa maybe .. this reason seems reasonable ... thanks bud
    drl431 likes this.
  8. TheDarkTiger
    TheDarkTiger , Jun 14, 2019 :
    the battery became really bad in the last few days from 6 hours of on screen time with 15 hours since last charged now i can get only 3 hours of on screen time which is weird because i use the phone the same , im thinking might me from software
  9. Kytharsis
    Nougat Jun 14, 2019
    Kytharsis , Jun 14, 2019 :
    After every update, you have to calibrate the battery.
  10. TheDarkTiger
  11. Intruder71
    Lollipop Jun 14, 2019
    Intruder71 , Jun 14, 2019 :
    I don't know who told you this but it's a myth from way back in the old days of android, it was never a thing.... Had to login to point this out as I have seen it mentioned a few times....
  12. TheDarkTiger
  13. Deactivated User
    Jun 14, 2019
    Kytharsis likes this.
  14. Cobustorro
    Cupcake Jun 17, 2019
    Cobustorro , Jun 17, 2019 :
    Dear OnePlus community,
    I'm facing a problem, which is my phone (6T) is a little more than half years old. Still functioning good, but the charger adapter is getting hot during the charging process( it didn't do it before), after that I can feel that the battery is literally hot.
    Even during using some bigger application like Waze, it is getting super hot, I barely can touch it.
    Why is my phone acting like this nowadays, even before never did this?
    Thank you for the advices!
    Márk
    PS: I'm using black theme, and all the ram easy options.
    F1580304493479 and Rudram2001 like this.
  15. L1560776023952
  16. Deactivated User
    Jun 17, 2019
  17. R1557564943013
  18. liutieguan
    Cupcake Jun 18, 2019
  19. sandeep jat
    Cupcake Jun 19, 2019
    sandeep jat , Jun 19, 2019 :
    I am practicing new 6t on Amazon last month and onw I am using is this is over heating problem and all so my Google assistant in not work properly
  20. F_Manoj_Venkat_Narayan_g
    Cupcake Jun 21, 2019
    C1548594517173 likes this.
