4
[UNIFIED] WiFi calling for Oneplus devices
  1. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Jan 3, 2020
    Liehjan , Jan 3, 2020 :
    I don't think so, when I contacted my carrier to get this feature on my phone they just told me that it will take 1-2 weeks for them to add the device to their supported list...
    #61
  2. G_ashish_jaswal_kbdb , via OnePlus 5T , Jan 3, 2020 :
    your country?
    #62
  3. Liehjan
    #63
  4. kiaara
    Cupcake Jan 4, 2020
    kiaara , Jan 4, 2020 :
    I got Vowifi on my Jio sim in iphone 7 yesterday. My OP7 also has jio sim but vowifi doesn’t work on it. I tried installing logkit and enabled vowifi but still nothing. Then i put my iPhone jio sim in OP7 but still no luck.
    Something is not done right.
    #64
    A1573386162497 likes this.
  5. Sameermehta2
    Honeycomb Jan 4, 2020
    Sameermehta2 , Jan 4, 2020 :
    As i confirmed with Jio customer care for my area op devices are currently not supported by their vowifi services,i am not confirmed but i guess some software needs to be pushed by OnePlus ,for airtel many people have reported it's working on op7t
    #65
  6. sakearzoo
    Ice Cream Sandwich Jan 5, 2020
    Stickied Post
    sakearzoo , Jan 5, 2020 :
    Hi , i have enabled vowifi on op5 and its working fine on airtel broadband with jio sim . I don't have airtel so I can't test.
    Steps to enable VOWIFI : (Try at your own risk)
    1. Dial *#800#
    2. Go to Oneplus logkit
    3. Go to function switch
    4. Check on Vowifi switch
    5. Reboot your phone
    6. go to settings -- wifi & internet -- sim & network
    7. Turn on WIFI Calling
    8. Reboot your phone
    Wait few minutes you will see volte will be replaced by vo-wifi .
    Try your luck with your broadband and your network .
    Here i have tested with Jio Sim with Airtel Xfiber broadband .
    If something goes wrong and you don't see your Volte options then go to settings -- system -- reset options -- reset wifi & mobile & bluetooth. It will revert to factory network settings. Note : it will reset all your network preference and saved wifi networks .
    #66
  7. sakearzoo
  8. sakearzoo
    #68
  9. sakearzoo
  10. sakearzoo
    #70
    vasanth88j likes this.
  11. vasanth88j
    Froyo Jan 5, 2020
    #71
  12. kiaara
    Cupcake Jan 5, 2020
    kiaara , Jan 5, 2020 :
    I tried this on my OP 7.
    Not working while it works on my iPhone 7
    #72
  13. sakearzoo
    welcome bro 😅
    #73
  14. #74
  15. sakearzoo
    always welcome 😅
    #75
  16. O1578212615081
    Cupcake Jan 5, 2020
    O1578212615081 , Jan 5, 2020 :
    It's working fine for me, and I am using airtel fiber internet and mobile connection on my OnePlus 6T.
    #76
  17. mani0283
    Froyo Jan 5, 2020
    #77
    Srinath_Chappidi likes this.
  18. #78
    musadsaiyed likes this.
  19. Sameermehta2
    Honeycomb Jan 5, 2020
    Sameermehta2 , Jan 5, 2020 :
    First
    First vowifi is network operator dependent ,vodafone doesn't have this service as of now ,check for coverage with Jio.
    Second OnePlus phones are currently not compatible with Jio vo wifi service as i confirmed with Jio customer care for my area,
    Third people have posted vo wifi is working on Airtel network on OnePlus devices
    Fourth you need to keep volte on in sim settings and there itself you will see an option of vo wifi.
    Hope this helps
    #79
    realamit likes this.
  20. shuvam3005
    Gingerbread Jan 5, 2020
    shuvam3005 , via OnePlus 7T , Jan 5, 2020 :
    A list of OnePlus phones are supported with VoWIFI with Jio and Airtel in India.
    But they are slowly rolling it out to the different cities, for now it has been rolled out in Delhi and a few other metropolitan cities and they're slowly branching out. Check with your carrier if your city is covered currently.
    Lastly, you need to own a Jio or Airtel broadband connection as per your carrier respectively for it to work. Having an Airtel sim and some other broadband connection won't work.
    #80
