4
[UNIFIED] WiFi calling for Oneplus devices
  1. N1540446700648
    Cupcake Apr 1, 2020
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Apr 1, 2020
  3. AbhilashSaikia
    Backstage Star Award 2021 Apr 1, 2020
    AbhilashSaikia , Apr 1, 2020 :
    Hey!
    It might be due to an unstable internet connection. Also, can you follow these steps -
    1. Enable Airplane Mode
    2. Disable Airplane Mode
    3. Enable WiFi again
    Can you check if VoWiFi is triggered after toggling Airplane mode?
    Regards.
  4. Dasstinker
    Eclair Apr 1, 2020
    Dasstinker , via OnePlus 7 Pro , Apr 1, 2020 :
    Hi Bro,
    Have tried everything but no luck.. My internet looks stable.. Have attached screenshot.. It doesn't shows VoWiFi on the status bar. I could see VoLTE.
  5. AbhilashSaikia
    That seems like a pretty solid internet connection. Can you go to Settings ->WiFi & Network -> SIM & Network -> Select the specific SIM -> Turn off WiFi Calling and then turn in on again?
    Please let me know if that helps.
  6. Dasstinker
    Eclair Apr 1, 2020
    Tried the same.. It didn't work either.
  7. AbhilashSaikia
    That's weird. Have you checked with other devices that are connected to the same WiFi network?
    Also, I would like to report this issue using the Feedback section of the Community. Please DM me if you require additional help in reporting it.
    Hope that helps!
    Regards.
  8. Lt. Mad Insane
    Froyo Apr 1, 2020
  9. Shekhar1707
    Cupcake Apr 1, 2020
  10. pablofg1978
    Head Moderator Head Moderator Apr 1, 2020
    pablofg1978 , Apr 1, 2020 :
    Please use the search before creating a new thread
    Thread merged
  11. Dasstinker
    Eclair Apr 2, 2020
    Dasstinker , via OnePlus 7 Pro , Apr 2, 2020 :
    I have only one WiFi calling options device that is my OnePlus 7 pro.. Still I am unable to use WiFi options... I have tried belo
    Network reset steps;
    go to settings >> system >>reset options >>Reset wifi, mobile and Bluetooth and check with the issue.
    Still I could see VoLTE not VoWiFi.
    Is there any other way to access my VoWiFi?
  12. skjadaun
    Cupcake Apr 3, 2020
  13. pablofg1978
    Head Moderator Head Moderator Apr 3, 2020
    pablofg1978 , Apr 3, 2020 :
    Thread merged
    skjadaun likes this.
  14. honeyv918
    Donut Apr 3, 2020
  15. Shekhar1707
    Cupcake Apr 3, 2020
  16. root_master
    Ice Cream Sandwich Apr 3, 2020
  17. Rishabh_Pandoh
    Gingerbread Apr 3, 2020
    Rishabh_Pandoh , via OnePlus 7T , Apr 3, 2020 :
    i tried searching the forum before creating the thread first. I'm using a 7T and jio supports Vowifi on 7t. i switched on the vowifi but for some weird reasons it's not connecting to wifi. I'm also using a jio fiber connection for wifi. pls suggest some methods to use vowifi
  18. pablofg1978
    Thread merged
  19. pablofg1978
    Thread merged, please do not create duplicate threads
