3
[UNIFIED] WiFi calling for Oneplus devices
  1. Shailender Sharma
    Marshmallow Feb 28, 2021
    Shailender Sharma , Feb 28, 2021 :
    Wi-Fi Calling option is supported on OnePlus 6 & above devices. The answer is negative for OnePlus 5T.
  2. pablofg1978
    Head Moderator Head Moderator Feb 28, 2021
    pablofg1978 , Feb 28, 2021 :
    Thread merged
    You need to ask to your carrier to add support for your device model
  3. Gekkouga
    Gingerbread Mar 1, 2021
    Gekkouga , via OnePlus 8T , Mar 1, 2021 :
    Recently for the past 15 days , I am experiencing a new problem with Calls not getting connected or can't call someone .
    I have installed Jio wifi router which supports Vo-Wifi callings ,
    I noticed that people can't call me or I can't call untill i reset connection with Airplane mode ,
    Today when I got back to House the phone got connected to wifi even though data is On ! And I received only a truecaller notification that call from "****" , but none called so I checked if I can call them but the call didn't get connect , so I turned airplane mode on and off and then after a while it is working .
    I thought problem was with my Sim card but no it's with my phone . Can someone help me ?
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 1, 2021
    Caomhin , via OnePlus 6T , Mar 1, 2021 :
    This might be worth a try. Others have found it to work.
    This is for all OP phones, however it discuses the 8 Series, but it should apply to any series as the protocols are the same.
    [GUIDE] Enable VoLTE & VoWiFi on all devices NO ROOT.
    https://forum.xda-developers.com/on...nable-volte-vowifi-devices-root-t4105817/amp/
    Log Kit 1.0
    https://www.apkmirror.com/apk/onepl...ase/onepluslogkit-1-0-2-android-apk-download/
    There are newer versions but I would suggest trying this with the details provided on XDA.
    If you do try the suggestions. Let us know how you get on.
  5. pablofg1978
    Head Moderator Head Moderator Mar 1, 2021
    pablofg1978 , Mar 1, 2021 :
    Thread merged
  6. pablofg1978
    Head Moderator Head Moderator Mar 2, 2021
  7. dr_bowtie
    Gingerbread Mar 3, 2021
    dr_bowtie , Mar 3, 2021 :
    Follow the information on my post. Even if it is set on the phone and enabled by your carrier it may not work due to the e911 conflict. The way to notice this is enable it after a reboot and if it flashes on and disappears quickly this is an indication.
    On a web browser (not on a phone app) open the portal where you'd go to pay your phone bill. If you dont have one online account, make one. You NEED to set up you Account Profile and select your Address and sync it with the e911 option. Once you do that it will more than likely start working. So far this has been the main issue with it not working is just the e911 conflict.
  8. cool_jaat_1711
    Cupcake Mar 5, 2021
  9. McJader
    Lollipop Mar 5, 2021
    McJader , Mar 5, 2021 :
    You need your network to even make a VoWifi call.
    J4t1np4r3kh likes this.
  10. Liehjan
    Marshmallow Mar 5, 2021
    Liehjan , Mar 5, 2021 :
    This is the issue... You need network for it to work
    J4t1np4r3kh and McJader like this.
  11. pablofg1978
    Head Moderator Head Moderator Mar 7, 2021
  12. B1611660770522
    Donut Apr 10, 2021
  13. drmartin
    Moderator Moderator Apr 10, 2021
    drmartin , Apr 10, 2021 :
    Moved to General Support
    Could you please describe your problem better, what you have tried to do, to fix it? Have you searched and tried those things you found yet?
    Caomhin likes this.
  14. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 11, 2021
    drmartin likes this.
  15. ShreyasPatil_
    Jelly Bean Apr 11, 2021
    Caomhin likes this.
  16. B1611660770522
    Donut Apr 11, 2021
