15
[UNIFIED] WiFi calling for Oneplus devices
  1. sreeram235
    Cupcake Dec 28, 2019
    #41
    BhagwanKishore likes this.
  2. revanth_p
    Donut Dec 28, 2019
    #42
  3. Sameermehta2
    Honeycomb Dec 28, 2019
    Sameermehta2 , Dec 28, 2019 :
    I confirmed with Jio customer care in Maharashtra Circle that op7t is not in the supported list for their vo wifi services ,that's pretty strange if op7t doesn't have it enabled then i don't know which handsets they are supporting.
    If anyone is getting vowifi services from Jio on op7t please confirm ( especially in Maharashtra Circle)
    #43
    nateavi and kamzee96 like this.
  4. gurdev.singh
    Donut Dec 30, 2019
    #44
  5. Prakahs
    Cupcake Dec 30, 2019
    #45
  6. Sameermehta2
    Honeycomb Dec 30, 2019
    Sameermehta2 , Dec 30, 2019 :
    I tried enabling the vowifi thru that *#800# command it doesn't have any option to enable it ,unless you root the device
    Second i noticed that when you use 2 sims in my case vodafone and Jio native video calling option under *#*#4636#*#* get disabled but as soon as you disable the vodafone sim it enables and Jio provides video calling natively
    There also no option to select networks independently for each sim which results in battery drain as the sim which is not using 4g is constantly fluctuating between 2/3g networks and also i cant choose 2/3g for both sims resulting in higher battery drain in case of bad coverage
    Pretty much messed up network configuration
    For Jio i have confirmed with their customer care op7t doesn't work with vo wifi services on their network
    #46
  7. NumberSix
    NumberSix , Dec 30, 2019 :
    If available from your network then you have not gone far enough in to the menu.
    Settings:
    Wi-Fi & Internet
    SIM & Network
    SIM 1
    Wi-Fi Calling
    #47
    GhstWrtr and Liehjan like this.
  8. Aakash7T
    Froyo Dec 30, 2019
    Aakash7T , via OnePlus 7T , Dec 30, 2019 :
    Only Airtel supports VoWiFi right now. To enable this, click on SIM& Network Settings, then click on Airtel. You'll see the option of WiFi calling. Enable it
    #48
  9. Sameermehta2
    Jio supports it but op7t isn't compatible with their services as per their customer service
    #49
  10. Sameermehta2
    If you are airtel you should get it ,if services are enabled by them,Jio isn't compatible with any OnePlus device
    #50
  11. rajesh voras
    Cupcake Dec 31, 2019
    rajesh voras , Dec 31, 2019 :
    Here is waiting for an update to make & received calls through WiFi.
    As everyone knows that know we are able make calls through broadband or wifi.
    But for this needs a system updates.
    So pls tell Exect date for this update in OP7.
    If its already updated, send the details to activate.
    Thanks
    #51
  12. harshit.b
    Ice Cream Sandwich Dec 31, 2019
    #52
    O1574194062837 likes this.
  13. G_ashish_jaswal_kbdb , via OnePlus 5T , Jan 3, 2020 :
    As we know , in India the Airtel and Reliance jio have started voice over Wi-Fi services.. so can we make a request to provide an OTA update for enabling VOWIFI feature in India,
    I am making the request as I assume VOWIFI supported by sd835..And global op5t support this feature..
    #53
  14. brajesh.sharma87
    Eclair Jan 3, 2020
    brajesh.sharma87 , via OnePlus 6T , Jan 3, 2020 :
    I live in Kolkata India. both jio and airtel have vowifi enabled for this circle yet I am not able to use it. reason:
    Airtel vowifi only works with Airtel broadband which only handful of users uses.
    Jio doesn't support oneplus devices yet for vowifi. About time, oneplus should release update enabling jio vowifi.
    #54
    nateavi likes this.
  15. Priyanshu Sharma , via OnePlus 6 Mirror Black , Jan 3, 2020 :
    Well, none of them has actually officially rolled out in Kolkata.. Jio has not enabled officially but yes it's working and Airtel VoWIFI is working in some areas.. Airtel has said it'll support all other broadband services and every wifi network but currently it's only working on Airtel broadband.. It's just starting so we've to wait a little bit for carriers to support these devices..
    #55
    ironass and Artemus. like this.
  16. Ray_ofLight
    KitKat Jan 3, 2020
    #56
  17. Liehjan
    Lollipop Jan 3, 2020
    Liehjan , Jan 3, 2020 :
    Your carrier has to add the device to their supported device list...
    #57
  18. #58
  19. #59
  20. Liehjan
    I don't think so, when I contacted my carrier to get this feature on my phone they just told me that it will take 1-2 weeks for them to add the device to their supported list...
    #60
