15
[UNIFIED] WiFi calling for Oneplus devices
  1. ragu2601
    Donut Jun 22, 2020
    ragu2601 , via OnePlus 5T , Jun 22, 2020 :
    After the latest Android 10 update for One plus 5T last week, the voice over wifi (WIFI Calling) facility was disabled. I am not able to see this option under SIM and network settings.. Can you let me know the reason for disabling the option. Please enable the same in the next update.
  2. Batman360
    Lollipop Jun 22, 2020
  3. F_Kartik_Rustagi_kOOR
    Honeycomb Jun 22, 2020
  4. Vodkapom
    Cupcake Jun 26, 2020
    Vodkapom , Jun 26, 2020 :
    Hey ! If your service provider provides this service for your device and it is activated, then there is a trick to active vowifi on a oneplus 7T Pro. You basically download a oneplus 7 logkit apk file. Then you install in on your phone. It won't break it, it's just and older version of the logkit. Once it's done, you dial *#800#, go to "function switch" and it should show the two options to enable volte and vowifi. Click the first one, then "cancel", click the second one, then "reboot". After rebooting, go to settings, WiFi and internet, Sim, select your sim card, and you should be able to activate both vowifi and volte. Cheers.
    I guess you can reinstall the previous logkit for 7T pro if you feel like it.
    olivier_lemo likes this.
  5. K_chetan_reddy
    Donut Jun 28, 2020
    K_chetan_reddy , Jun 28, 2020 :
    Since the upgrade, on the status bar I am unable to see wifi calling option
    Please confirm if any other users too face the same issue
  6. A1571629772612
    Cupcake Jun 30, 2020
  7. K_chetan_reddy
    Donut Jun 30, 2020
    K_chetan_reddy , Jun 30, 2020 :
    Oneplus 5T supports wifi calling
    Might be that you are using oneplus 5
    A1571629772612 likes this.
  8. A1571629772612
    Cupcake Jul 1, 2020
  9. Shinjan_Saha
    Cupcake Jul 3, 2020
    Shinjan_Saha , Jul 3, 2020 :
    Facing issue in oneplus 7t. Both the volte and vowifi keeps dropping at random intervals. My indoor network is weak. Hence I rely on vowifi but it keeps disappearing even when I am connected to a stable wifi.
    Volte also keeps dropping randomly.
    How to fix this issue? Any ideas?
  10. CAGIRISH
    Eclair Jul 5, 2020
    CAGIRISH , via OnePlus 3T , Jul 5, 2020 :
    Hello Carl and Team Oneplus!
    Please if you guys can provide VoWifi for Oneplus 3 & 3T. I know you guys will Never Settle for anything less!
    We use Airtel, Jio & Vodafone here in India.
    Please help. Thank You so much.
    Never Settle!
  11. Matt 80
    Lollipop Jul 5, 2020
    Matt 80 , Jul 5, 2020 :
    Update support has ended for the oneplus 3/3t, you will not receive any new features.
    Paschfire likes this.
  12. Paschfire , via OnePlus Community App , Jul 6, 2020 :
    If your 3/3T doesn't already support/offer VoWiFi with your current carrier(s), than unfortunately nothing can be done to change this.
    As update support for these devices has ended, as they have already reached their EOL cycle. No further updates will be released via OTA from OnePlus.
  13. abhinav.rmil
    Cupcake Jul 7, 2020
  14. S1569301958111
    Cupcake Jul 8, 2020
  15. R.Peter , via OnePlus 7 Pro Mirror Gray , Jul 8, 2020 :
    VoWifi depends on the mobile carrier and the system as well. The carrier must support it and the system must have the carrier's profile for VoWifi. I'm in contact with Oneplus because I have a subscription for VoWifi at my carrier (Telekom aka T-Mobile), they confirmed it is available for me, but it seems only OP8 has the profile for it, thus, I can't enable it among my SIM's settings. VoLTE is similar.
    Ask your carrier if VoWifi is enabled for you, if so, report pn this link: forums.oneplus.com/feedback
  16. Viswak Parthiban O K , via OnePlus 6 , Jul 9, 2020 :
    I am using OnePlus 6 for past 2 years. After OS upgrade VOWIFI is not working properly. I need to restart the mobile or use airplane mode or restart wifi to bring it back. Please help.
  17. the_o2
    User of the Year 2018 Jul 10, 2020
    the_o2 , Jul 10, 2020 :
    Settings > system >Reset Options > Reset Wi-Fi, mobile & Bluetooth (it will delete your saved Wi-Fi passwords and Bluetooth settings also so keep that in mind)
    And restart your phone.
    And see if it fixes the issue.
    Viswak Parthiban O K likes this.
  18. Viswak Parthiban O K
    Cupcake Jul 10, 2020
    Viswak Parthiban O K , via OnePlus 6 , Jul 10, 2020 :
    Hi,
    I followed the instructions, however I am facing the issue still.
    Any other solution???
    Thanks,
    Viswak
  19. Dixit18889
    Cupcake Jul 12, 2020
