15
[UNIFIED] WiFi calling for Oneplus devices
  1. sakearzoo
    Ice Cream Sandwich Jan 7, 2020
    sakearzoo , Jan 7, 2020 :
    yours working because you are connected to TD-SCDMA. if it's other lte band then you will face problem . like if vowifi goes away then you have to reboot to get back vowifi . it switchs from vowifi to volte but not volte to vowifi in my case
  2. Anonymous Fox
    Honeycomb Jan 7, 2020
  3. sakearzoo
    currently its not possible .. airtel works with airtel broadband only 😅 .
  4. sakearzoo
  5. khalidahmed8
    Eclair Jan 7, 2020
  6. Depon158
    Eclair Jan 7, 2020
  7. sakearzoo
    it is being routed bro .. but it doesn't shows .. you can easily identify while you receive incoming calls. check it
  8. Depon158
    Eclair Jan 8, 2020
  9. Vignesh Manoharan
    Froyo Jan 8, 2020
  10. freeflyer
    Cupcake Jan 8, 2020
    freeflyer , Jan 8, 2020 :
    yes..
  11. A1578479043426
    Cupcake Jan 8, 2020
  12. Q1570793380695
    Cupcake Jan 8, 2020
  13. Liehjan
    Lollipop Jan 8, 2020
    Liehjan , Jan 8, 2020 :
    Does your carrier support it on 7T?
  14. Q1570793380695
    Cupcake Jan 8, 2020
  15. Liehjan
    You didn't answer my question, have you checked with your carrier that they support 7t?
  16. Q1570793380695
    Cupcake Jan 8, 2020
  17. Liehjan
  18. Q1570793380695
    Cupcake Jan 8, 2020
  19. Nilesh bajaj26 , via OnePlus 7T Glacier Blue , Jan 8, 2020 :
    hey members,
    jio has rolled out wifi calling pan India starting 7th Jan 2020
    For switching it on it say go to settings---wifi setting-- switch on wifi calling
    But this is not yet available in OnePlus device. all other handset in my area getting wifi calling option.
    Waiting for update from manufacturer'oneplus'
    Q1570793380695 likes this.
  20. pablofg1978
    Nougat Head Moderator Jan 8, 2020
    pablofg1978 , Jan 8, 2020 :
    You need to contact jio and ask them to support your device
    Liehjan and the_o2 like this.
