17
[UNIFIED] WiFi calling for Oneplus devices
  1. jayanatraj
    Cupcake Sep 3, 2020
  2. jayanatraj
    Cupcake Sep 3, 2020
  3. A1547584176746
    Cupcake Sep 4, 2020
    A1547584176746 , Sep 4, 2020 :
    I've searched the threads and cannot get wifi calling enabled.
    I'm using Oxygen 10.0.12 with a 7t on the AT&T network in the US.
    Sim slot 1, mobile data enabled.
    I just switched from and iPhone that had wifi calling so I know that AT&T has this feature.
    I've tried the *#800# method. I see that my VoLTE is enabled, but there is no box or wording to enable Wifi Calling.
    Any suggestions on how to enable Wifi Calling?
    Thanks
  4. amar611
    Cupcake Sep 10, 2020
    amar611 , Sep 10, 2020 :
    I dont see wifi calling option on my phone. I relocated to a place where the phone signals are not great, ATT, Verizon both suck here. I was hoping to see wifi calling but I dont see that option at all. This looks like a oneplus 7 pro issue rather than verizon. Is there going to be a patch for this soon?
  5. kanchanpadmakar
    Cupcake Sep 13, 2020
    kanchanpadmakar , Sep 13, 2020 :
    I am unable to use wifi calling service in one plus 5T. Tried using *888# but didn't worked. Can anyone help me with this?
  6. M1514643423807
    Cupcake Sep 17, 2020
  7. aashishallumalla
    Eclair Sep 19, 2020
  8. Liehjan
    Lollipop Sep 19, 2020
    Liehjan , Sep 19, 2020 :
    If you don't have it by now... Then don't expect it for a 3yo device.
  9. the_o2
    User of the Year 2018 Sep 21, 2020
    the_o2 , Sep 21, 2020 :
    You can manually enable it by using logkit if you want
  10. koushik501s
    Cupcake Sep 21, 2020
    koushik501s , via OnePlus 5 , Sep 21, 2020 :
    Hello Team,
    Please provide an update to enable the wifi calling option on one plus5 model as signal is very slow in my area and not able to recieve the calls. Thanks
  11. aashishallumalla
    Eclair Sep 23, 2020
  12. megha0103
    Donut Sep 23, 2020
    megha0103 , Sep 23, 2020 :
    Despite a lot of threads on this, OnePlus doesn't seem bothered about fixing such a small functionality on their handsets which they ironically call Flagship devices.
    This small feature is VoWiFi or Wi-fi calling.
    I have seen a lot of threads but no thread has a solution.
    VoWiFi works fine for a while but goes away very soon. It is small yet a much needed functionality.
    This feature works perfectly fine on a low end Nokia handset and ALL OF SAMSUNG DEVICES that support wifi calling. There is a reason why still Samsung has such a good user base. Because of such issues OnePlus might never be like them.
    L1543480229745 likes this.
  13. koushik501s
    Cupcake Sep 24, 2020
  14. sanojshiwantha96
    Stickied Post
    sanojshiwantha96 , Sep 24, 2020 :
    After update OP5T to Android 10, missing switches to VoWiFi and VoLTE.
    In this tutorial i will show how to fix this.
    It is enabling VoWiFi and VoLTE even in Poland with T-Mobile, Orange and Play carrier.
    This method doesn't required root.
    0. Make sure that you just enabled the VoWiFi and VoLTE in your carrier first !!!
    1. Download and install the old LogKit:https://www.apkmirror.com/apk/onepl...lease/onepluslogkit-1-0-android-apk-download/
    3. Type *#800# --> oneplus Logkit --> Function Switch --> enable VoLTE and VoWifi switch
    4. Open Settings --> WiFi & Intenet --> SIM & netwok --> enable VoLTE and VoWifi switch
    5. Connect your phone to PC
    6. Type *#801# in Phone app and enable Serial and Full-port switch
    7. Download and unzip the EfsTools with config files includes: https://drive.google.com/folderview?id=1CUPpk5xGoV3cH6HTFLJSIZuavY5tW5Qm
    8. Open CMD as Administrator on the PC, navigate to the folder where you extract the files (eg. cd c:\EfsTools-0.10-modded-1.2-win32)
    9. Now execute the following commands:
    EfsTools.exe efsInfo
    EfsTools.exe writeFile -i mcfg_autoselect_by_uim -o /nv/item_files/mcfg/mcfg_autoselect_by_uim
    EfsTools.exe writeFile -i mcfg_autoselect_by_uim -o /nv/item_files/mcfg/mcfg_autoselect_by_uim -s 1
    EfsTools.exe uploadDirectory -i mcfg_sw.mbn -o / -v
    EfsTools.exe uploadDirectory -i mcfg_sw.mbn -o / -s 1
    Thats it. Commands with "1" on at the end are for the second SIM card.
  15. mjabraham , via OnePlus Nord Gray Onyx , Sep 24, 2020 :
    I'm from Kerala, India, my WiFi calling is not working properly. my normal calling working just fine.
    anyone facing the same issue??
    during WiFi calling, I can hear everything but the people on the other side can't hear me.
    please help
    saju3252 and P1597073810823 like this.
  16. Mn Revanth
    Cupcake Sep 25, 2020
    Mn Revanth , Sep 25, 2020 :
    On my OnePlus 7t pro the wifi Calling feature gets turned off every now and then.
    Please help me out.
    even the wifi and mobile network automatically turns on and off.
  17. Dr_Jiyas_Azeez
    Dr_Jiyas_Azeez , Sep 25, 2020 :
    When iam on the VoWifi..the calls keep disconnecting again and again..having oneokus 7 pro...please help
  18. newnews
    Froyo Sep 27, 2020
    newnews , Sep 27, 2020 :
    thank you. I installed Logkit and enabled the volte and vowifi switch, after restarting the phone I enabled volte/vowifi in SIM settings. Now VoLTE works fine. My carrier does not support vowifi. I did use Efstool. Is EfsTool necessary to activate the VoLTE and VoWiFi?
    sanojshiwantha96 likes this.
  19. Tillya
    Cupcake Sep 27, 2020
