Unlock 7 Pro via OnePlus 7 Pro Mirror Gray
  1. Bernest44
    Gingerbread Mar 28, 2020
  2. Swejuggalo
    KitKat Mar 28, 2020
  3. Bernest44
  4. Swejuggalo
    KitKat Mar 28, 2020
    Swejuggalo , via OnePlus 7 Pro , Mar 28, 2020 :
    Unlocking bootloader always wipes. Never heard of any walkaround.
    The purpose is that you want to root and stuff?
  5. Bernest44
    Bernest44 , via OnePlus 7 Pro Mirror Gray , Mar 28, 2020 :
    I want total access to do what I want. It's mine to brick. [e]1f602[/e][e]1f602[/e]. Juuust kidding. lol
    Swejuggalo likes this.
  6. Bernest44
  7. Swejuggalo
    KitKat Mar 29, 2020
  8. Swejuggalo
    KitKat Mar 29, 2020
  9. Bernest44
    Gingerbread Mar 29, 2020
    Bernest44 , via OnePlus 7 Pro Mirror Gray , Mar 29, 2020 :
    Yes.....waiting in T-Mobile to unlock the SIM. They say 24-48 hour bullshit. I'll be glad when they are gone. Worst technical support ever. How they become the 5G leader is a farce. And 5G isn't on my radar until Fall season here....another 6 months.
  10. Bernest44
    I have to do a full factory re-install to unlock. My question is...after the unlock, will Oxygen Updater do everything I need as far as updates? It's gonna revert back to Android Pie. How should I approach? If you happen to know. Thanks my friend!
  11. Swejuggalo
    KitKat Mar 30, 2020
    Swejuggalo , via OnePlus 7 Pro , Mar 30, 2020 :
    Depends what kind of factory reinstall you do. Rollback file, msmtool unbrick method? Or simply factory reset? A normal factory reset keeps the current installed version. The other 2 don't.
    If you indeed get to Pie, the only upgrade steps you need is either OTA or manually download upgrades in steps. You probably need 10.3.0 before flashing 10.3.1. The OTA way does this automatically.
    The latest one always exists in Oxygen Updater. But you may need a older one. That can be found here
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
