8
ROM [UNOFFICIAL] [5.1] Euphoria-OS 1.1 w/ CAF Kernel by Crazy_Boy^ [Nov 21][FINAL]
  1. Evokkimus
    KitKat Oct 28, 2015
    Evokkimus , Oct 28, 2015 :
    Sultan's kernel is what comes stock.
    #61
    PCesar.Cercal likes this.
  2. PCesar.Cercal
    KitKat Oct 28, 2015
    PCesar.Cercal , Oct 28, 2015 :
    and Ak the boy crasy where I find ?
    #62
  3. Evokkimus
    KitKat Oct 28, 2015
    Depends, do you want only AK kernel or the AK Kernel build by Ak?
    #63
  4. BassVity
    Jelly Bean Oct 28, 2015
    BassVity , Oct 28, 2015 :
    Can I expect customisation as much as nuclear Slim in this ROM?
    Anyways I can't wait to check the ROM out!
    #64
  5. Evokkimus
    KitKat Oct 28, 2015
    Well I'm not sure how much NucSlim has but this ROM has hella lot customization options. Also the features are really well organized in the settings. I think this ROM has the best and most useful features among Sultan's awesome kernel magic.
    #65
  6. BassVity
    Thanks @Evokkimus!
    Yep, like you said, the only main thing I look in a ROM for nowadays, is CAF (Ironically, I'm on CM12.1 for now)
    I'll flash it and try it out. :)
    #66
    Evokkimus likes this.
  7. Evokkimus
    KitKat Oct 28, 2015
    #67
  8. Antoine Vdb
    KitKat Oct 28, 2015
    Antoine Vdb , Oct 28, 2015 :
    Already did that and resetting to factory settings just gets me back to 8.2.99 which is also crashing
    #68
  9. Antoine Vdb
    KitKat Oct 28, 2015
    There are links in the OP. Please read that before asking links ;)
    #69
  10. iriad
    Gingerbread Oct 28, 2015
    iriad , Oct 28, 2015 :
    Did you try Pico TK Gapps?
    #70
  11. Antoine Vdb
    KitKat Oct 28, 2015
    The Gapps don't change anything it's the GPS version. Two of my friends are getting that too and I don't other Gapps will fix this. For now I reenabled keep awake, auto start and wake up in the Privacy Guard
    #71
    iriad likes this.
  12. iriad
    I'm with Sultan's rom and it's great, but wanna give a try to this one... should I flash the firmware? Why?
    #72
  13. JustSaying
    JustSaying , Oct 28, 2015 :
    Hey can you make the screenshot from your battery performance? From 100% to 15 orso
    Thanks in advance!
    #73
  14. Antoine Vdb
    KitKat Oct 28, 2015
    I don't understand anything about firmware but if you're on a recent ROM I think you don't have to flash the firmware
    #74
  15. Deactivated User
    Oct 28, 2015
    #75
  16. ice552
    Froyo Oct 29, 2015
    ice552 , Oct 29, 2015 :
    I am working on Cm13
    Euphoria stopped working on 5.1 :(
    And latest CAF features are buggy
    So current build should be fine for now
    #76
  17. Evokkimus
    KitKat Oct 29, 2015
    Evokkimus , Oct 29, 2015 :
    It's ok, the latest build is damn fine, no need for a newer build actually.
    You go ahead and concentrate on the CM13 mate. Hopefully I can get a 6.0 daily driver soon :D
    Well I might already have one, if TB worked.
    #77
    girishb86 likes this.
  18. pjcsantos
    Froyo Oct 29, 2015
    pjcsantos , Oct 29, 2015 :
    The same here, Sultan did a great job with his rom and I was really happy with it. But after reading some comments about this one I had to try it, and so far I am really enjoying this Euphoria rom. I get more customization and last night the battery only dropped 2% without using any battery saving apps.
    #78
  19. PCesar.Cercal
    KitKat Oct 29, 2015
    PCesar.Cercal , Oct 29, 2015 :
    Wher I find your cn13 Build?
    #79
  20. amankumar2508007
    Honeycomb Oct 29, 2015
    #80
