13
ROM [UNOFFICIAL] [CM12.1] Cyanogenmod 12.1 (Beta) for OnePlus 2
  1. regalstreak
    Gingerbread Aug 29, 2015
    regalstreak , Aug 29, 2015 :
    Cyanogenmod 12.1 for the OnePlus 2 (beta)
    This has not been made by me. This is a work of Grarak on XDA Forums. Here is the Original Thread Link On XDA Forums
    Code:
    #include <std_disclaimer.h>
    * Your warranty is now void.
    * I am not responsible for bricked devices, dead SD cards,
    * thermonuclear war, or you getting fired because the alarm app failed. Please
    * do some research if you have any concerns about features included in this ROM
    * before flashing it! YOU are choosing to make these modifications, and if
    * you point the finger at me for messing up your device, I will laugh at you.
    Sources
    https://github.com/Grarak/android_de...eplus_oneplus2
    https://github.com/Grarak/android_ke...neplus_msm8994
    https://github.com/Grarak/proprietary_vendor_oneplus
    https://github.com/CyanogenMod/andro...ce_qcom_common
    What does work?
    - Booting (whooo)
    - Display
    - Touchscreen
    - Camera
    - Audio
    - RIL
    - Sensors
    - Wifi
    - Bluetooth
    - GPS
    What does not work?
    - Fingerprint
    - Laser Autofocus
    - Enforcing selinux
    TODO
    - I can't get a working dt.img from sources! This build still uses dt.img from stock boot.img
    This ROM is currently quite stable. I am using it as daily driver.
    Downloads
    ROM
    Installation
    • Boot into Recovery
    • Wipe Cache/Data
    • Install Zip
    • Select the ROM, optional GApps (64-bit)
    • Done
    Credits
  2. SoniaB
    Head Moderator; Community Hero 2020 Head Moderator Aug 29, 2015
    SoniaB , Aug 29, 2015 :
    Maybe ask a mod to move it to OnePlus 2 section?
    Its in OPO just now, [​IMG]
  3. Me1256
    KitKat Aug 29, 2015
    Me1256 , Aug 29, 2015 :
    You may want to include an installation guide, some screenshots, a list of features, etc.
  4. regalstreak
    Yes please :)
    I will soon :D
    pa5t1s, Deactivated User and Ceasedd like this.
  5. championspike
    Ice Cream Sandwich Aug 29, 2015
    regalstreak likes this.
  6. Me1256
    KitKat Aug 29, 2015
    Also add a little cm12 banner at the top to make it look nice.
    #HYPEorGTFO and regalstreak like this.
  7. rikardo1979
    Community Veteran Aug 29, 2015
    pgidia, pa5t1s, harsh.garena and 3 others like this.
  8. Ceasedd
    Marshmallow Aug 29, 2015
  9. regalstreak
    Im using an app for op forums... It ****** up i guess :/ i posted in op2 but it went in op1 :p
  10. Ceasedd
    Ceasedd , Aug 29, 2015 :
    May be a candidate for pinning?
  11. regalstreak
    I'm in tuition class right now... Came across thus :v ill postmore stuff when i get home :)
    Ceasedd likes this.
  12. rikardo1979
    rikardo1979 , Aug 29, 2015 :
    I dont see a reason. If this is something users find useful and well discussed than in stays at top
    Ceasedd likes this.
  13. Ceasedd
    Ok.thanks for responding. Will try this when the bugs are fixed.*Heads to XDA*
    pgidia, #HYPEorGTFO and regalstreak like this.
  14. Ceasedd
    Never mind. @PVS Kharoud posted this before when the build started.Nothing work than.It's getting build quickly.:)
  15. regalstreak
    Bump. Thread completed :D You may now pin this post if you want to.
  16. inffy
    KitKat Aug 29, 2015
    inffy , Aug 29, 2015 :
    No for the pin.
    If this is needed it will stay on top as users will post on the thread.
    pa5t1s, bwells88 and regalstreak like this.
  17. mkernbach
    KitKat Aug 30, 2015
  18. SimonFullerImagery
    Jelly Bean Aug 30, 2015
    SimonFullerImagery , Aug 30, 2015 :
    i'll go for it when the fingerprint sensor and laser focus comes to life. The only good thing i have to say about Oxygen right now is the boot animation.
    Nickexp and regalstreak like this.
  19. SimonFullerImagery
    Jelly Bean Aug 31, 2015
    SimonFullerImagery , Aug 31, 2015 :
    This guy already flashed it and made a vid, seems to work very well apart from the obvious hardware omissions, certainly 'daily driver' worthy as it stands.
    suhask83 and regalstreak like this.
  20. npasha001
    Gingerbread Aug 31, 2015
    npasha001 , Aug 31, 2015 :
    I love cyanogen and RR roms and they are very good and customizable and if Oxygen can add the themes and Camera app and lot of Statusbar customization then that would be really good either we can use the unofficial CM rom for this unless we have any issues like heating and wait for the stable one until we have stable
