15
[UNOFFICIAL] OOS 4.7.5
  1. vpjoshi007
    Froyo Dec 15, 2017
  2. Gopi Kiccha
    Gingerbread Dec 15, 2017
  3. dustupajisk
    dustupajisk , Dec 15, 2017 :
    Small change libmmcamera2_q3a_core.so (camera librairies)
    - Small change in libstagefright_soft_avcdec.so (Used for hardware h264 decoding)
    - Updated libstagefright_soft_avcenc.so (Used for hardware h264 encoding)
    - Updated libwebrtc_audio_preprocessing.so (Related to audio processing)
    - Updated OPDeviceManager
    - Updated OnePlusCamera
    - Kernel updated from 4.4-G1712062242 to 4.4-G1712122320
    - Updated firmware files : a540_zap, ipa_fws
  4. Aevangelist
    Eclair Dec 15, 2017
    Aevangelist , Dec 15, 2017 :
    As long as nothing is announced and I don't receive anything in Germany, I suppose it's just a regional update for India.
  5. dustupajisk
    you can use navbar apps available on playstore
    it doesn't need root
    Nitesh Pishey likes this.
  6. sandipbarot19
    Eclair Dec 15, 2017
  7. Nitesh Pishey
    Eclair Dec 15, 2017
    Nitesh Pishey , Dec 15, 2017 :
    Thanks for the suggestion. Still, It'd be great if it could be fixed via software update. Cheers.
  8. kishori02
    kishori02 , Dec 15, 2017 :
    m having dis nav bar
    can u tell me what's wrong in ur nav bar
  9. Gurupranesh
    Eclair Dec 15, 2017
  10. Nitesh Pishey
    Eclair Dec 15, 2017
    There's nothing wrong with the nav bar, it's just that instead of a white appeal, it would be better if it could blend with the keyboard/theme. See the difference [e]1f447[/e][e]1f447[/e]
    It'd be more appealing if it were transparent.
  11. sree_12
    Cupcake Dec 15, 2017
    sree_12 , Dec 15, 2017 :
    Even I received this update and when I downloaded and updated it my battery started draining very fast.
    please suggest me a solution.
    harrygonsalvis likes this.
  12. pablofg1978
    Head Moderator Head Moderator Dec 15, 2017
    pablofg1978 , Dec 15, 2017 :
    Thread merged
    RonaldM likes this.
  13. Infrequent66
    Infrequent66 , Dec 15, 2017 :
    Try smartlock...
  14. Mickemust
  15. SyamKG
    Ice Cream Sandwich Dec 15, 2017
  16. vpjoshi007
    Froyo Dec 15, 2017
    vpjoshi007 , Dec 15, 2017 :
    camera is better in 4,7,4
  17. _vasukabra_
  18. _vasukabra_
  19. dustupajisk
    here are the changes
    A. Mack, Cheetosdust and kaihp like this.
  20. Rakeshm89
    Froyo Dec 15, 2017
    Rakeshm89 , Dec 15, 2017 :
    go to stechguide.com and download 4.7.2 update and follow the instructions.. and boom... 4.7.2
    Gopi Kiccha likes this.
