71
Unofficial Week In Review: Volume 2 Issue 16 - Sycophants Everywhere & SoniaB's Reign Ends
  1. Tobikage
    Nougat Jul 19, 2021
    Tobikage , Jul 19, 2021 :
    Declined.
    You're supposed to object within 5 sec or less.:rolleyes:
    B_Wrath, Mr. BG, KaranRIyer and 5 others like this.
  2. camohan
    Assistant Head Moderator Assistant Head Moderator Jul 19, 2021
    camohan , Jul 19, 2021 :
    overruled.
    B_Wrath, KaranRIyer, McJader and 5 others like this.
  3. manojsurya99
    Jelly Bean Jul 19, 2021
    KaranRIyer likes this.
  4. Tobikage
    Nougat Jul 19, 2021
    B_Wrath, Mr. BG, McJader and 3 others like this.
  5. camohan
    B_Wrath, Mr. BG, Tobikage and 3 others like this.
  6. Bruno Lugnani
    Ice Cream Sandwich Jul 19, 2021
    Bruno Lugnani , via OnePlus 9 Pro , Jul 19, 2021 :
    Read carefully what's written on OnePlus official website and SD888 performances, well i paid nearly Euro 1000 to have a de-powered OP9 PRO? Were defective my Euro?
  7. Tokolozi
    Most Original Avatar Jul 19, 2021
    Tokolozi , Jul 19, 2021 :
    So why do all phones with an 888 suffer more or less the same fate?
    B_Wrath and Dresa91 like this.
  8. Tokolozi
    Power on tap, do you leave your taps wide open all the time at home?
  9. Bruno Lugnani
    this is not a good excuse for OnePlus, today Xiaomi released AN update for M11 Ultra where they state to have lowered temperature of 5 degree, are you sure OP cannot adjust the Oxygen and Kernel so to get a similar result without blacklisting 300 apk and depowering it?
  10. Tokolozi
    Well we'll need to see if they can implement as such. Who says xioami didn't do something similar to OnePlus.... Wouldn't be the first time either from their side.
    Also remember the mi11 ran much much hotter than the op9 in the beginning. So these 5 degrees were probably much needed.
    Anyways, the whole 888 story is just a re-run of the 810 series. The only way this will really be solved is if Qualcomm gets their heat management better in the 888+ or later series.
    Sure kernels and software improved temps over time, but the key issue was the silicon itself.
    B_Wrath, McJader and Dresa91 like this.
  11. Bruno Lugnani
    So who should reimburse us or supply a new smartphone 888+ free of charge? Qualcomm, OnePlus or both? Look marketing now present on OnePlus website is cheating about performances of Dragon SD888, don't you agree?
  12. Tokolozi
    No one.
    It was your choice to buy a device that quick after release. And marketing is and always be just that, marketing.
    Just like Tesla states their car can do 0-100 in 3.x seconds, they won't mention that it's only there with 80+ percent charge on the battery.
    If you want to find a lawyer to do a class action lawsuit against OP(PO) and QC.... Good luck. Doubt anyone will win that battle unless you get another big(ger) company involved. If you're lucky you'll see your reimbursement by the time the OP18 is released.
  13. Bruno Lugnani
    Look, i have bought 8 Pro, also with its 5G a really bad support from OP, then i have bought 9 PRO, it is not my fault is their product is defective, this is a manufacturer's responsabiliy for sure, but not mine! And for sure next smartphone i will buy in future will not be OnePlus or belonging to BBK Elecronics, and it is all very strange since Chinese are always very touched by a thing called REPUTATION!
    My Euro have not been defective!
    nerdkabir likes this.
  14. Tokolozi
    You know what they say about doing the same thing over and over again expecting a different result.
    Your product is also not defective, it's not working like you expect it too, but at this point it's clear that it's per-design. Hell most early reviewers, at least the thorough ones commented about the heating of the device.
    You however did choose to buy it at/close to release. Something I would never recommend, especially with electronics. Most perticularly if you don't want to face issues such as this.
    Alright, better luck next time. I've probably heard this sentence 1000x of times already, and then the same users go and buy the next OnePlus device anyways. Maybe you're the exception :)
  15. Bruno Lugnani
    yes 1 time ok, 2nd ok, third one 100% NO and yes I am the exception. 😉
  16. KaustubhNaik95
    Honeycomb Jul 19, 2021
    Tokolozi likes this.
  17. Rusty NZ
    Marshmallow Jul 20, 2021
    superplus, Tokolozi, SoniaB and 3 others like this.
  18. Basudev7
    Gingerbread Jul 20, 2021
  19. Bittoo06
    Jelly Bean Jul 20, 2021
    superplus, Tokolozi, SoniaB and 2 others like this.
