Unusual sound beep while charging?
  1. damncared
    Froyo Nov 15, 2019
    damncared , Nov 15, 2019 :
    Hello everyone
    just encountered a sudden bug while charging my phone
    I put that on charge and it's normal when I put the charger plug in the usb C port it makes a sound and the lighting animation happens
    but while charging the phone suddenly makes that particular sound
    I faced it for the first time and I'm using android 10 right now stable
    can someone tell me what's the actual issue
  2. Kytharsis
    Marshmallow Nov 15, 2019
    Kytharsis , Nov 15, 2019 :
    Not an issue or bug, supposed to do that.
  3. damncared
    Froyo Nov 15, 2019
    yes yes
    but why it makes sound all of a sudden
    there's no power issue
  4. Kytharsis
    Probably losing rapid charge. Try cleaning out the port.
  5. damncared
    Froyo Nov 15, 2019
    it was on charge.. I put it n left the phone as it is
    and suddenly heard like it started charging again but there was nothing on display n phone was charging too
  6. damncared
    Froyo Nov 15, 2019
    okey are you sure this is not an software issue?
    I had no problem in pie before but my phone restarted twice after the android Q update
  7. Kytharsis
    Anything can happen with a bad Android build.
  8. damncared
    Froyo Nov 15, 2019
    well
    can you help me to tell me is it the stable version I'm using or not
