5
Update 11.2.10.10 broke my OP9 Pro
  1. Jreyes95
    Cupcake Nov 25, 2021
    Jreyes95 , Nov 25, 2021 :
    Im curious to how they will even correct the issue. Im guessing well have to send in our phones? I unfortunately just sold my 7 pro and have no back up.
  2. Pichnareach
  3. petrera
    petrera , Nov 25, 2021 :
    I have the same issue with my Oneplus 9. How the hell can i be ixed when i cannot turn on then phone?
  4. L1579470376972
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 25, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Nov 25, 2021 :
    This would probably require MSM-tool to restore or a remote session letting Oneplus do it for you.
    This is of course a terrible misstake to roll out. But if this happened while on 12 beta seeing a 11 update should be a HUGE warning sign.
    If you have already installed it but not rebooted. Don't reboot. Wait for more info.
    L1579470376972 likes this.
  6. L1579470376972
    L1579470376972 , Nov 25, 2021 :
    brand new, One Plus 9+,
    Ok, so I wait for more instruction
  7. Swejuggalo
    If installed and rebooted and already bricked, then it needs to be fixed. There is a chance to get a solution to reverse it for those that has not yet rebooted after having it installed. A incorrect update was delivered to 8 beta users too once. That time it could be solved and the update reversed for those that had not rebooted yet. (no brick that time... Just data loss).
    Let's hope it can be done this time too.
  8. pooh81
    Eclair Nov 25, 2021
    pooh81 , Nov 25, 2021 :
    I solved it thanks to this tool
    https://onepluscommunityserver.com/list/Unbrick_Tools/OnePlus_9_Pro/EU_LE15BA/R (11)/
    Power your device off.
    Let it cool down for one minute.
    Hold both volumes in to get in Qualcomm EDL mode and the screen will stay black. While holding, plug in the USB cable from your phone to your computer. Let volumes go alter plugged in.
    Wait some time (should not be longer than ~300 seconds).
    Enjoy your brand new device.
    if your smartphone does not detect you, do this and try again:
    Unplug your phone, get in fastboot mode, turn off phone, wait 15 secondes and get back in Qualcomm EDL mode. You can also try using a USB 2.0 port instead of a 3.0 one.
  9. Pekko
    Donut Nov 25, 2021
    Pekko , Nov 25, 2021 :
    Thanks, but i already solved this; ordered Galaxy S21 Ultra. I’ve been using OnePlus phones for five years, but I don’t need this kind of shitty engineering work anymore. These are basic things and these mistakes should no longer come at this level.
  10. Caomhin
    Caomhin , Nov 25, 2021 :
    Hi, just wondering does this solution involve Data loss?
    Liehjan and the_o2 like this.
  11. N1631627015914
  12. pooh81
    Eclair Nov 25, 2021
  13. Less_e
    Less_e , Nov 25, 2021 :
    Thank you pooh81.
    It's a pity. Both ways you suggested won't work with my oneplus 9pro. MSM doesn't find my phone :/. Is there another alternative?
  14. pooh81
    Eclair Nov 25, 2021
    I too could not find the phone. go to fastmode disconnect the phone. open msm as instructed, when it asks you for the smartphone press both the volume keys and connect the cable.
    Mauricio_1995 likes this.
  15. Mauricio_1995
    Mauricio_1995 , Nov 25, 2021 :
    [QUOTE = "pooh81, post: 23825067, member: 2011528"] Lo solucioné gracias a esta herramienta
    https://onepluscommunityserver.com/list/Unbrick_Tools/OnePlus_9_Pro/EU_LE15BA/R (11) /
    Apague su dispositivo.
    Déjelo enfriar durante un minuto.
    Mantenga presionados ambos volúmenes para entrar en el modo Qualcomm EDL y la pantalla permanecerá negra. Mientras lo sostiene, conecte el cable USB de su teléfono a su computadora. Deje que los volúmenes se modifiquen enchufados.
    Espere algún tiempo (no debe ser más de ~ 300 segundos).
    Disfrute de su nuevo dispositivo.
    si su teléfono inteligente no lo detecta, haga esto y vuelva a intentarlo:
    Desenchufe su teléfono, entre en modo fastboot, apague el teléfono, espere 15 segundos y vuelva al modo Qualcomm EDL. También puede intentar usar un puerto USB 2.0 en lugar de uno 3.0.
    Lo solucioné gracias a esta herramienta [/ QUOTE]
    POR FAVOR PARA LA VERSION GLOBAL LE2125 POR FAVOR
  16. Jreyes95
    Press only both volume keys or both volume keys + power button to get into edl mode.
  17. Jreyes95
    That website isnt very user friendly. Can you go in further detail on how to use it? Did you have to download drivers? and when you say after plugging it in you say enjoy your new phone does it automatically update it?
  18. Mauricio_1995
    HOLA AMIGO PUEDE AYUDARME CON EL ARCHIVO MSM PARA LA VERSION GLOBAL LE2125 PORFAVOR, YA QUE LA VERSION QUE PUBLICÓ ES LA ESTADOS UNIDOS AYUDA PORFAVOR
    #38
  19. J0hnD0e
    #39
  20. Caomhin
    #40
    J0hnD0e likes this.
