213
[UPDATE 17/09/15]COS 12.1-YOG4PAS1NO | Bugs & Discussion Thread
Thread Status:
Not open for further replies.
  1. monkey29992
    Cupcake Aug 30, 2015
    monkey29992 , Aug 30, 2015 :
    Can anyone upload the original mixer_paths.xml? I messed it up and forgot to back up and now my phone has no sound :(. Thanks a lot!
  2. Aslate
    Aslate , Aug 30, 2015 :
    I got the OTA update last night and now my Bluetooth doesn't turn on. I bought some headphones for my holiday next week and can't use them now. Any way to downgrade/fix this ?
  3. t3k1lla
    Eclair Aug 30, 2015
    t3k1lla , Aug 30, 2015 :
    Hi,
    Can you please help me.
    I have rooted phone and I'd like to know how to proceed to update and root my phone without loosing all datas.
    Thanks for help
  4. daroczig
    daroczig , Aug 30, 2015 :
    Same here :( Reboot solved the problem.
  5. politas
    Froyo Aug 30, 2015
    politas , Aug 30, 2015 :
    Has anyone figured out how to get a lock screen wallpaper back? The live blur is cute, but not what I want. I wanted a Cyanogen phone because I liked the customisation abilities. Rather annoying to override my settings!
  6. Silvijo
    Froyo Aug 30, 2015
    Silvijo , Aug 30, 2015 :
    Battery is crap now. I see that phone does not go sleep at all. Any solution ?Screenshot....
  7. politas
    Froyo Aug 30, 2015
    Flash the full zip, then flash SuperSU again. No loss of data.
  8. Sanjay Singh Rawat
    Gingerbread Aug 30, 2015
    Sanjay Singh Rawat , Aug 30, 2015 :
    Thanks...good to know...
    HR_778 likes this.
  9. aj2989
    Honeycomb Aug 30, 2015
    aj2989 , Aug 30, 2015 :
    OMG, I'm glad I didnt flash yet, yikes.... Already phone battery sucks in CM12S.
  10. lazloinsf
    Froyo Aug 30, 2015
    lazloinsf , Aug 30, 2015 :
    Update did not mess w/ either my lockscreen wallpaper or my home window one but if you go out to Settings : Themes : Customize - there is a tap-panel to reset it - just remember to also tap the CheckMark (lower right corner) as you back-arrow out of changes you have made...
  11. amego
  12. t3k1lla
    Eclair Aug 30, 2015
    I download the zip of firmware and install it with trpw right?
    Then just install again supersu?
    Did I well understood?
    Thanks
  13. Talha Tailor
  14. albertrix2000
  15. jmenzler
    jmenzler , Aug 30, 2015 :
    So, got my OTA last night, installation worked fine on my encrypted no root stock recovery OPO. Very good performance, more fluent, excellent app startup times ... and no bugs discovered. Even video playback is working here now! No battery drain, from the first tests it's like the 12S - wich was absolutely ok for me. Great incremental - do I need a OPT?? ;-)
    sickdogg1974 and Tee Jing Long like this.
  16. slamerjuniho
  17. slamerjuniho
    slamerjuniho , Aug 30, 2015 :
    BBM : 5718AB92 - Tas Sepeda Hydropack Specialized, Shimano, Giant Kereen dan Mantab!!!
    Infonya disini Gan:
    PIN BBM : 262878A6 / 5718AB92
    SMS : 08179257500
    WA : 08979152298
    Tas Sepeda Ransel Hydropack BBM 262878A6 - Buat agan-agan yang suka bersepeda, ini ane mau tawarin barang yang high quality recomended, murah made in Bandung.
    Tas Sepeda Ransel Hydropack anti air, anti hujan, anti badai :D, Harga Bersaing, Kwalitas Bersaing, ane berani jamin ini tas bagus bangeed Dah...
    Bahannya neeh dari dari Dolby di kombinasikan bahan 300d Soft tahan air di padu padankan sama sablonan yang modern dan cihuy tahan air dan panas
    Ane jamin agan-agan gak bakalan kecewa
    Merek : Lokal
    Dimensi : -
    Bahan : Dolby + 300D Soft Tahan Air
  18. albertrix2000
    albertrix2000 , Aug 30, 2015 :
    We talk english sir!
  19. jenkinsmark24
    jenkinsmark24 , Aug 30, 2015 :
    My australian OnePlus 1 is not very useful now with the latest update
  20. dlaravind
    Donut Aug 30, 2015
    dlaravind , Aug 30, 2015 :
    Has anyone noticed battery performance deterioration with this update? There is a noticeable drop in battery performance. Its especially bad now when on only 4G (Wifi seems unaffected).
    On lock screen as well, I keep seeing service unavailable although I can make/receive calls. LTE network is also fine.
    There is also frequent crashes on Photos app (though Google app, I did not notice this before).
