213
[UPDATE 17/09/15]COS 12.1-YOG4PAS1NO | Bugs & Discussion Thread
Thread Status:
Not open for further replies.
  1. tonycpsu
    Donut Aug 31, 2015
    tonycpsu , Aug 31, 2015 :
    Flashed the update last night, but had to roll back because enabling Xposed GEL Settings caused an endless "System UI has stopped" loop. I was able to install the Xposed framework itself, but I've had no luck getting the GEL settings module working. Has anyone gotten it to work, and if so, did you have to do anything special to make it work?
  2. Maxl
    Ice Cream Sandwich Aug 31, 2015
    Maxl , Aug 31, 2015 :
    Haven't had any issues yet, and battery life is pretty good!
    think likes this.
  3. JSR290799
    Gingerbread Aug 31, 2015
    JSR290799 , Aug 31, 2015 :
    Is it I've heard mix opinions on the battery life it's all down to opinions and weather you get an early batch phone that has had less quality control (if any)
    Maxl and JSR2907 like this.
  4. decahillane
    Froyo Aug 31, 2015
    decahillane , Aug 31, 2015 :
    Boot into recovery and clear the cache and data partitions (system reset)
  5. ngalarza
    Cupcake Aug 31, 2015
    ngalarza , Aug 31, 2015 :
    is it normal that my recovery is gone? I understand the phone has to be re-rooted after an update like this but now i have the stock cyanogenmod recovery. I flashed using philz recovery.
  6. Fluxxytux
    Fluxxytux , Aug 31, 2015 :
    Bugs Found:
    1.
    My OPO was sitting at my desk screen on, then i noticed it was playing up...
    I have a pin lock set up to activate 15secs after screen is off, automatically screen timeouts in 1 min.
    I noticed the OPO just flickering quickly with animation between the lock and currect screen randomly and consistently in cycles of 2-8secs no matter which currect screen/app i was on.
    I restarted my OPO, everything seems fine, till it starts again...
    2.
    When the first problem mentioned above starts occurring, my OPO doesnt seem to lock at all.
    3.
    The home key stops working. after a while of using my OPO the home key function stops working, in my case taking me back to the launcher. i get feedback(vibrate ) when I press the softkey but no action.
    I will keep this reply post updated if I find anymore issues.
    anyone got any kernal recommendations? let me know. thank you!
    :p
  7. rontom
    Froyo Aug 31, 2015
    rontom , Aug 31, 2015 :
    Settings > Developer options > uncheck (disable) "Update Cyanogen recovery".
  8. odjov
    odjov , Aug 31, 2015 :
    I've been using the official COS 12.1 w/ stock kernel for some days now.
    The only issue I got is the WiFi connection is not stable. It disconnects every 2-3 minutes for a brief moment, then reconnects.
  9. bubu83
    bubu83 , Aug 31, 2015 :
    Hello. since I updated I have problems. Google Play services drain the battery. I did a clean install.
  10. rontom
    Froyo Aug 31, 2015
    First post in this thread has suggestions for wifi/data issues.
    odjov likes this.
  11. TheOneWhoWantsAOne+One
    Honeycomb Aug 31, 2015
  12. pradeep020694
    Donut Aug 31, 2015
    pradeep020694 , Aug 31, 2015 :
    Hi in d new new dialer i cnt see my full contact details when there s a call incoming.. All i c s d numbers n the first letter of the persons name... Please help...
  13. Deactivated User
    Aug 31, 2015
  14. odjov
    Before posting I had read and done what was suggested in the first post, didn't work for me. Thanks though.
  15. 7wX
    7wX , Aug 31, 2015 :
    Am i the only one that experience issues with the SMS Application after the update?
    When i quick reply from the notification bar it goes smoothly. But if i try to open the application to reply then i crashes after minutes of loading or sometimes i can enter the textbox to type a message but it's really really slow (like 1 minute to show me 50 characters typed)
  16. rondog648
    rondog648 , Aug 31, 2015 :
    Go into settings,Lock screen and set it back up.
  17. one plus one = awsome
    Donut Aug 31, 2015
  18. vinoottanz
  19. Deactivated User
    Aug 31, 2015
  20. Ramgautham
    Ramgautham , Aug 31, 2015 :
    OTA increemental
