213
[UPDATE 17/09/15]COS 12.1-YOG4PAS1NO | Bugs & Discussion Thread
Thread Status:
Not open for further replies.
  1. rishisaigal
    Gingerbread Aug 26, 2015
    rishisaigal , Aug 26, 2015 :
    Dont know how it works but if you notice, this bug is only present where contact is using whats app.
  2. azriel46
    Froyo Aug 26, 2015
    azriel46 , Aug 26, 2015 :
    Google Photos wasnt working for me neither. Went to the playstore, updated and worked.
    ironm likes this.
  3. rajasekaran2050
    rajasekaran2050 , Aug 26, 2015 :
    Hi.. i didn't root my phone. Directly applied the update
  4. Evokkimus
    KitKat Aug 26, 2015
    Evokkimus , Aug 26, 2015 :
    I love COS12.1 :D
    Probably gonna flash Ak kernel though. I've been using Mixmash V11-G profile, are there any better ones though? I prefer UI and Gaming performance over battery life.
    HR_778 likes this.
  5. Rysiko0812
    Eclair Aug 26, 2015
    Rysiko0812 , Aug 26, 2015 :
    No bugs so far. NFC toggle no problem after turn on, unstable cellular solved with reset APN, no problem with WiFi or cellular signal strength, I have dirty flashed over stock 12s
    HR_778 likes this.
  6. i5xswipe
    Ice Cream Sandwich Aug 26, 2015
    i5xswipe , Aug 26, 2015 :
    My Google Photos works fine.
    HR_778 likes this.
  7. HR_778
    KitKat Aug 26, 2015
    HR_778 , Aug 26, 2015 :
    Thank you for your input. I'm gonna clean up the list soon.
  8. hlin9
    Honeycomb Aug 26, 2015
    hlin9 , Aug 26, 2015 :
    Nope, I did not, but there was an update to the photos app after I updated to CM12.1
  9. i5xswipe
    I have no issue with the NFC Toggle in quick settings. Simply adding it from Settings-->Notification Drawer-->Select and Order tiles. Works fine and displays it for me.
    HR_778 likes this.
  10. jjrojoc
    Froyo Aug 26, 2015
    jjrojoc , Aug 26, 2015 :
    Obviously if you kill it's kill, it was happened to me before, not running in background up to start application again
  11. HR_778
    KitKat Aug 26, 2015
    Yeah, I'm gonna update it.
  12. Al-Azraq
    Eclair Aug 26, 2015
    Al-Azraq , Aug 26, 2015 :
    Problem solved mates, it works by deleting the app data or, as have you said, by just updating the app as it seems that flashing de ROM flashes an old photos app version as well.
    Everything else is working well so far, the screen feels more responsive and the rom is smoother tham CM12. Did a dirty flash with no noticeable problem.
    i5xswipe and azriel46 like this.
  13. pigmeej
    Community Veteran Aug 26, 2015
    sirius90black and HR_778 like this.
  14. HR_778
    KitKat Aug 26, 2015
    Awesome. I'll remove it from the list
    i5xswipe likes this.
  15. scottrc
    Eclair Aug 26, 2015
  16. aravipistha
    aravipistha , Aug 26, 2015 :
    That is likely because you already had the 241 radio installed :)
    iriad likes this.
  17. Deactivated User
    Aug 26, 2015
  18. HR_778
    KitKat Aug 26, 2015
    Guys I still seem to be having issues with my network signal. It is very unstable and keeps disconnecting. I've reset to default APN settings too but still no luck.
  19. aravipistha
    I dont understand what you are saying actually :/ but in a generic sense you may have to root the device to uninstall the dialer and reinstall google dialer..
  20. markstein
    markstein , Aug 26, 2015 :
    Deinstall TrueCaller Service, then it is Stock Cyanogen (Android 5.1?) again.
    The new Browser can also be deleted. The switching of Chrome to Bing is annoying, but can be changed easily in Settings.
