213
[UPDATE 17/09/15]COS 12.1-YOG4PAS1NO | Bugs & Discussion Thread
Thread Status:
Not open for further replies.
  1. HR_778
    KitKat Oct 8, 2015
    HR_778 , Oct 8, 2015 :
    First page.
    macc74 and Deactivated User like this.
  2. Mrreed98
    Honeycomb Oct 8, 2015
  3. TForesto
    Gingerbread Oct 8, 2015
    TForesto , Oct 8, 2015 :
    He has no clue. He's just a hater.
    bklyn000 likes this.
  4. freddytireguy
    freddytireguy , Oct 8, 2015 :
    He's not the hater...you are. You can't stand the idea that users are so fed up with the bugs in 12.1 that they will do anything to get their phone working again. That includes going all the way back to 44S where EVERYTHING WORKS AS DESIGNED! Please stop being condescending... It is not appreciated.
  5. Deactivated User
    Oct 9, 2015
    TForesto likes this.
  6. rondog648
    Gingerbread Oct 9, 2015
    rondog648 , Oct 9, 2015 :
    I'm one of the others that does'nt have one problem with cos12.1. I use it basically as a phone and never worry about sot, i go for idle stand by time. I keep location, wifi,data all turned off till i need it and after my normal phone calls and a few text messages i had 129 hours with 18% battery left. I'll take those kind of stats anytime....:rolleyes:
  7. freddytireguy
    Honeycomb Oct 9, 2015
    freddytireguy , Oct 9, 2015 :
    How about a screenshot proving that. Now up to 260 pages!
  8. rondog648
    Gingerbread Oct 10, 2015
    rondog648 , Oct 10, 2015 :
    muerte and Deactivated User like this.
  9. freddytireguy
    Honeycomb Oct 10, 2015
    freddytireguy , Oct 10, 2015 :
    Impressive. I just don't know how you are doing it. I use my phone a lot and was lucky to get 4 hours SOT. I just get a day of use on one charge. I will post my numbers tomorrow. I just finished charging so it reset.
  10. macc74
    Donut Oct 10, 2015
  11. freddytireguy
    So here are my numbers so far...not bad with 58% left.
  12. jstepa
    KitKat Oct 10, 2015
    jstepa , Oct 10, 2015 :
    So now you are posting to your own posts, patethic, get some frends, go outside from your cellar :confused:
    nexus123 likes this.
  13. Deactivated User
    Oct 10, 2015
  14. drdexter
    Eclair Oct 11, 2015
    drdexter , Oct 11, 2015 :
    Does anybody know if it is secure install the september ota, and where can i find the changelog for the most recent ota.?
  15. Deactivated User
    Oct 11, 2015
  16. lazloinsf
    Froyo Oct 12, 2015
  17. balancebox
    Cupcake Oct 12, 2015
    balancebox , Oct 12, 2015 :
    been using Yog4pas1no with 230 band since launch and had no problem. Only notice there was an issue when a friend brought me their OPO with LTE issues. the radio is very buggy. I takes a while to lock onto provider and would not get LTE signal, only H+.
  18. rondog648
    Gingerbread Oct 12, 2015
    rondog648 , Oct 12, 2015 :
    There are some fixes on the first page for LTE issues.
  19. bbgarnett
    bbgarnett , Oct 12, 2015 :
    I am having the same issues with no LTE and have gone through the fixes on the first page but still only getting H+.
  20. rondog648
    Still sounds like a apn problem. Check with his provider and make sure the apn's are right,or if you both are using the same provider, check your settings and make sure his matches...:)
