448
[UPDATE] CM 11S 05Q OTA Released
  1. newmad
    Honeycomb Feb 11, 2015
  2. nebrandroid
    nebrandroid , Feb 11, 2015 :
    You reminded me of this :D:
    zopi and zepphead like this.
  3. zepphead
    Lollipop Feb 11, 2015
    nebrandroid likes this.
  4. TonyTony
    Cupcake Feb 11, 2015
  5. nebrandroid
    FYI
    I flashed the incremental update manually, and so far everything is great. The MaxxAudio is pretty cool!
    zepphead likes this.
  6. rontom
    Froyo Feb 11, 2015
    rontom , Feb 11, 2015 :
    I lost root after flashing with TWRP (recovery) but was prompted by TWRP to re-establish via Google Play. I used the play store but you can also flash SuperSU along with the update. Hope this helps;)
  7. Nik T
    Donut Feb 11, 2015
    Nik T , Feb 11, 2015 :
    Guys, the time is missing from the top right corner at the lock screen after updating to 11S 05Q... Actually it is nowhere on the lock screen. This was a very useful info to have... I dont want to use another app just to get it back. This feature should be built in... Please, fix this porblem!!!
  8. zepphead
    zepphead , Feb 11, 2015 :
    Thanks ... i may try this later today.
  9. nebrandroid
    You have a BIG clock in lock screen, no?
  10. firoz
    KitKat Feb 11, 2015
  11. ammyt
    ammyt , Feb 11, 2015 :
    Try setting your screen brightness to auto and turn on all screen enhancement options and hold your phone against the sun... Magic :eek:
  12. stephaneousset
    Gingerbread Feb 11, 2015
    stephaneousset , Feb 11, 2015 :
    Have you tried to check and unchecked in display and reboot?
  13. xjotjotx
  14. ammyt
    Well for me speedwise there seems to be no tangible difference between 44S and 05Q. Actually looking at it there isn't really any difference that I felt between them except for the totally new awesome MusicFX (luckily all options working like a charm here) and screen light calibration (sunlight enhancement actually works now.) Other than that, it's 44S with some more camera options.
    What I really want is the ability to view media details on gallerynext! This is so frustrating as the only thing you can see is date of capture.
  15. ShadySpeedster
    Ice Cream Sandwich Feb 11, 2015
  16. TheRad1
    TheRad1 , Feb 11, 2015 :
    I've been on Temasek CM12 since late November and decided to check out this update yesterday. Flashed the 44S extras zip and then restored a nandroid backup of 44S I had on my SD. Within just a few minutes I received the OTA! Sweet! At first it wouldn't flash as I had the audio effects config for V4A in my vendor folder. Pushed the correct file from a stock 44S download I found on my PC and bingo I'm on 05Q all in less than 15 minutes.
  17. jai0505
    jai0505 , Feb 11, 2015 :
    yeap after update the phone is very smooth to operate. Max Audio is good.
  18. noobtubed1875
  19. milsau19
  20. ShadySpeedster
    ShadySpeedster , Feb 11, 2015 :
    Just now? I still haven't got mine
