448
[UPDATE] CM 11S 05Q OTA Released
  1. fader
    Cupcake Feb 12, 2015
    fader , Feb 12, 2015 :
    Just recieved the update herein Sweden now! DL it right now! Installing... MIA
  2. mralbert
    Gingerbread Feb 12, 2015
  3. fader
  4. stewa2jm
    Honeycomb Feb 12, 2015
    stewa2jm , Feb 12, 2015 :
    Ha ha! I post here and suddenly it appears on my phone! Classic! .... I'll lose twrp and root... then I'll have ads again, and my firewall will be broken! NO!!!!!! .... it'll have to wait until after work.
  5. windshear
    Ice Cream Sandwich Feb 12, 2015
    windshear , Feb 12, 2015 :
    So ? What is ur point? What is the point of ur attitude?
  6. sethH92
  7. timartinho
  8. justinb928
  9. cody1960
  10. bgm13
    Froyo Feb 12, 2015
  11. Carnivore
    Carnivore , Feb 12, 2015 :
    I believe this is a bug in the latest version of twitter. I just had the same problem upgrading my tablet with a new CM ROM, when you try to add the twitter widget to the desktop it throws an "App isn't installed" error message. There are complaints about this in the user reviews for the Twitter app on Google Play too.
    To fix this:
    Uninstall your twitter app. Then download the previous version of twitter (5.43.0) from AndroidDrawer.com. Tap the .apk file to install it. You will need to be rooted and allow installation of apps from "Unknown Sources" under the security tab in your Android settings.
    Once the older version of Twitter is installed, add the widget to your desktop. Now you can update Twitter to the latest version via Google Play without breaking your widget, but make sure the widget is on your desktop first.
  12. scrivz69
    Jelly Bean Feb 12, 2015
    scrivz69 , Feb 12, 2015 :
    Lol went back to 44s and just got the OTA, so Ignored it, Like my battery life too much.
  13. Deactivated User
    Feb 12, 2015
    ronaldrenteria likes this.
  14. Deactivated User
    Feb 12, 2015
  15. Its_rudy
    Froyo Feb 12, 2015
  16. johmss
    johmss , Feb 12, 2015 :
    It is just me? it seems there are more animations (when you choose an option, changing menus, choosing a contact un WA, ETC...)
  17. rodstoppable
    Eclair Feb 12, 2015
  18. mwayner
    Lollipop Feb 12, 2015
    mwayner , Feb 12, 2015 :
    Lol. Updated this morning and, other than the audio stuff, there is no discernable difference to 44S. Even the Swiftkey is optional. Phone worked perfectly before and still does. Neither improvement nor degradation in performance.
  19. dentalexel
  20. sa00044
    sa00044 , Feb 12, 2015 :
    My OTA uodate just arrived. I'll install it and let you know if I lost root access too. I have enabled the survival mode of su root so hopefully it won't be necessary to reinstall it.
    By the way, have you restored root on your device and if so, did you have to unlock the bootloader again in order to do it?
