UPDATE for CM12.1 Nightly caused a bootloop.
  1. mnm104
    Gingerbread Apr 20, 2015
    mnm104 , Apr 20, 2015 :
    HELP
    I decided to update from my CM12 nightly to the CM12.1 nightly, now its causing a bootloop and repeating the "Upgrading Apps" process.
    Any help is appreciated.
    THANKS!
  2. sdrem00
    Froyo Apr 20, 2015
    sdrem00 , Apr 20, 2015 :
    I had the same thing happen to me. You do need to flash a gapps 5.1 pkg. which I did, and got a bootloop, Went back and wiped cache, dalvik and data. Worked fine from there. When the setup screen comes up you have an option to restore your apps and data.
  3. Drave
    Eclair Apr 26, 2015
    Drave , Apr 26, 2015 :
    Do you think there's a way to do it without wiping data ? I kinda want to keep them ... And i'm to lazy to backup them up and restore them ...
