Update from 12.1-YOG4PAS1N0 to 12.1-YOG4PAS3JL without loosing data, twrp and root
  1. mohamed.saleem
    Froyo Dec 11, 2015
    mohamed.saleem , Dec 11, 2015 :
    Hi everyone,
    I am currently running 12.1-YOG4PAS1N0 rooted with twrp 2.8.6.0
    Can I update to 12.1-YOG4PAS3JL directly without flashing 12.1-YOG4PAS2QL?
    How can I update without loosing data, twrp and root?
    Thanks in advance.
    saketraushan likes this.
  2. mihir_jha
    Eclair Dec 11, 2015
    mihir_jha , Dec 11, 2015 :
    Yes, of course you can ;)
    Just download the ROM's full zip from here http://builds.cyngn.com/cyanogen-os...91bf047f5/cm-12.1-YOG4PAS3JL-bacon-signed.zip (650mb) and then flash it via TWRP without wiping data, just clear cache nd dalvik after flashing.
    Then press reboot, a message will pop up in TWRP saying that u hav probably lost root after flashing, so swipe to root now. And afterwards update ur super SU binaries after reboot...
    This way u wont lose anything.
    And remember that you have to flash the whole ROM zip as the small OTA zips can't be flashed by TWRP (it can only be done by CM recovery).
    Hope this helps..:cool:
    munk, drmodify, Fonetix and 3 others like this.
  3. tssu
    Cupcake Dec 17, 2015
    tssu , Dec 17, 2015 :
    If I were you I'll hang on to YOG4PAS1N0. I've just updated to YOG4PAS3JL, and I'm finding ways to downgrade to YOG4PAS1N0. Reason? With YOG4PAS3JL, I lost the use of Note field in Contacts. To activate the Note field, I have to go to my Google account, add in the Note and sync.
  4. mohamed.saleem
    Froyo Dec 17, 2015
  5. croatan
    Froyo Dec 18, 2015
    croatan , Dec 18, 2015 :
    Can I upgrade my oneplus one from CM12.0 to CM12.1 ? without loosing data?
    I already got rooted btw.
  6. mihir_jha
    Eclair Dec 20, 2015
    mihir_jha , Dec 20, 2015 :
    Of course you can. Just download your desired ROM's zip file and follow the steps i said above.
  7. mihir_jha
    Eclair Dec 20, 2015
    Hows ur battery life bro?? I got a discharge rate of 1% in 5min while browsing internet with mobile data on (which means approx 8.3 hrs SOT) on CM13 , But on COS12.1 its abt 1% discharge in 2.5 to 2.8 min with mobile data on and browsing.
  8. se7enlyn
    Ice Cream Sandwich Dec 21, 2015
    se7enlyn , Dec 21, 2015 :
    must i flash gapps?
  9. mihir_jha
    Eclair Dec 22, 2015
    mihir_jha , Dec 22, 2015 :
    No, GApps are included in the CyanogenOS zip itself.
  10. se7enlyn
    Ice Cream Sandwich Dec 23, 2015
    se7enlyn , Dec 23, 2015 :
    thanks
  11. mihir_jha
    Eclair Dec 23, 2015
    se7enlyn likes this.
  12. AbhayKadam
    Cupcake Feb 18, 2016
    AbhayKadam , Feb 18, 2016 :
    Guys, I am way behind...i am still using yng1tas17l (android 5.0.2)...have lost the track now and confused which is the latest OS i should flash...heard that YOG7DAS2K1 can be updated OTA only...i have a rooted OPO...need advise on which OS should i flash so that my phone can have the latest one...
  13. mihir_jha
    Eclair Feb 19, 2016
    mihir_jha , Feb 19, 2016 :
    Flash the 12.1-YOG4PAS3JL full zip and then flash the latest YOG7DAS2K1 OTA.
  14. mihir_jha
    Eclair Feb 19, 2016
  15. AbhayKadam
    Cupcake Feb 21, 2016
  16. mihir_jha
    Eclair Feb 22, 2016
  17. Deactivated User
    Mar 18, 2016
