Update problem.
  1. G_Mangesh_Kulkarni_uylF
    Cupcake Jan 20, 2017
    G_Mangesh_Kulkarni_uylF , Jan 20, 2017 :
    Have lost all my contacts after i updated my OnePlus 3 to android 7.0 today. I am unable to retrieve my contacts from google or .vcf file from my phone. Pls help on urgent basis.
  2. Irfan Ibrahim
  3. jonathan1uk
  4. Avinash Nalode
    Cupcake Jan 22, 2017
  5. AvishekRakshit
    Donut Jan 22, 2017
    AvishekRakshit , Jan 22, 2017 :
    Hi. Have you experienced this problem on WhatsApp or some other application or on the default contacts app? If this has happened on WhatsApp, or any other app, just go to Apps under Settings and then choose the relevant app and under permissions, allow the app to access contacts.
  6. iliyas_op3
    iliyas_op3 , Jan 22, 2017 :
    One of my friend face same problem. Restarting mobile and waiting for couple seconds did the trick.
  7. sumitraj1632
  8. abhayk9
    abhayk9 , Jan 22, 2017 :
    I'm using oneplus 3. my phone's dialer stop working after 7.0 OTA update.anyone with this issue..?
  9. F_Ravi_Khatwani_SeMk
    Cupcake Jan 30, 2017
  10. sumitraj1632
    Cupcake Jan 31, 2017
    sumitraj1632 , Jan 31, 2017 :
    Ws facing the same issue... However what I have done is.. First I have remove my account and then reset my phone. Again I have login from my google account and was able to get back my contacts. The only thing I lost in this process was the application which I have downloaded from google play store.
  11. sasi_kumar.s
  12. krishnagoyal
    Cupcake Feb 6, 2017
    krishnagoyal , Feb 6, 2017 :
    After installing the oxygen is 4.0.2 update I am facing some battery problems . I charged my phone to 100℅ and not even doing Anything on the phone just leaving it on standby the battery drain to 90% and also the wifi was off then also the battery was finishing so badly . after playing some games like marvel contest of champions for 2 hours battery drain to 33℅ and the battery saver mode is also not that good so I please request to improve the battery performance
    and even facing problems in location and when ever iam calling my phone is automatically on speaker mode
    Thanks
  13. msvr
    Honeycomb Feb 6, 2017
    msvr , Feb 6, 2017 :
    yup, mine was facing way worse, it has hardly a percent per hour/two, but suddenly it started like 3-4% an hour even without connecting to wifi/data. overnight dtop would be around 25.. even flashed the ROM again, but nothing helped..
  14. srousseau
    Cupcake Feb 6, 2017
    srousseau , Feb 6, 2017 :
    Hello,
    I cant updateto nougat 7.0 because of tbe developer mode.
    In dezail:
    Every time I got the Massage that a Update of oxygen... Is available. I download it and start to install. Now there comes the developer-mode. Ive no idea what to do to install the dowmloaded update. The same when I deactivat that Mode. I also reset the app settings. Please help me, i think a manual in which directory the file is and where to push would be helpful.
    Best regards
    Sebastian
