Isn't it amazing how anything I say you seem to change it.
This is what I said
What desease do you suffer from?
Googles battery life woes are well documented over the years and OP record with heat, battery drain etc is the stuff of legends. If you go to the support section for every single device back to the OPO it will read the same, the sheer volume of comment on the subject is undeniable.
I have to say some of you comment are laughable.
1. Custom kernel if you know HOW to use a custom kernel you can extend your battery life considerably, thr easiest and most simple way to get an immediate effect is to lower the clock speeds of the SOC. There are many other things you can tweak dependent on the tool you have, there are also many members on this forum that will tell you your placebo statement comes from a man with limited experience.
2. Wakelocks too have been an issue that stops devices from enter a deep sleep and therefore draining the battery considerably faster. OP device's suffered with this due to the lack of robustness of earlier OS's. Reading through some of the threads not a while lot has changed.
I dunno what Huawei, Xiaomi or Poco have to do with what I said but the killing of apps is to save on power and if you needed to hold something in memory
the ability to lock the item in memory is there. Didn't you know that? So why would you need to sacrifice anything?
Comical thread full of opinions and not facts.
Here have a butchers
XDA
You are not as Mystic as your name might suggests.
