18
Updated!Best build prop tweaks for your opo.
  1. bombadier
    KitKat Jun 22, 2015
    tEf0o likes this.
  2. Enyalius
    Jelly Bean Jun 22, 2015
    Enyalius , Jun 22, 2015 :
    No shit, sherlock.
    tandu and tEf0o like this.
  3. ianchu97
    Donut Jun 22, 2015
  4. Slatter191
    Lollipop Jun 22, 2015
  5. tEf0o
    tEf0o , Jun 22, 2015 :
    Some i know, some i havent tryed, some made issues, some were unknown.
    More spec on each line of tweaks, so know what it wreck's....
    ddlittlejohn likes this.
  6. jackdsparker
    Ice Cream Sandwich Jun 22, 2015
    jackdsparker , Jun 22, 2015 :
    What I've never undestood is that there are these tweaks available so why don't oneplus just implant them into the build prop anyway
  7. Slatter191
    Slatter191 , Jun 22, 2015 :
    Exactly, so true and correct.
  8. tEf0o
    As some have big/small issues.
    And some apps might fail.
  9. Pachenko
    Froyo Jun 22, 2015
    Pachenko , Jun 22, 2015 :
    I think you have an incorrect line here as i searched on google...
    This one "com.qc.hardware=1" need to be like this "com.qc.hardware=true"
    Correct me if i am wrong...
    tandu likes this.
  10. bombadier
    KitKat Jun 22, 2015
    bombadier , Jun 22, 2015 :
    What I like about this thread is that all these tweaks are listed but absolutely no description about what any of them do has been included, thanks for the list of things you can add that may improve somethings,may make somethings worse and may give you a bootloop as you are messing with a very important file , top job flower
    tandu likes this.
  11. royz0r
    royz0r , Jun 22, 2015 :
    Tried to add soms tweaks in the build.prop but it wouldnt let me save the changes. Someone had an idea why it doesnt save it?
  12. brolaire
    Honeycomb Jun 22, 2015
    brolaire , Jun 22, 2015 :
    You need to use an editor with root. You can try ES File Explorer with root permission. It's what I used to set the dpi to 400. But in all honesty, I wouldn't do it, it's way too risky to play with the Build.Prop...
  13. bombadier
    KitKat Jun 22, 2015
    Because you are working on a system file and you do not have root privileges and will not have it mounted as RW
    As I have previously said you can get into a bit of bother messing with the build.prop which is why think carefully before editing it as you can get a bootloop/problems
  14. royz0r
    Is it good to only use the better scrolling tweak and the battery saver without losing performance tweak?
  15. brolaire
    No idea, as I said, I only touched that file for the dpi, if something goes wrong, you can get a bootloop, you can brick... Do a backup and try it, if you want, but if something goes wrong, don't come and bite me!
  16. rbagdai
    The Lab - OnePlus 8T Reviewer Jun 22, 2015
    rbagdai , Jun 22, 2015 :
    Waiting for someone to try this. After which i will go on for it :)
  17. rikardo1979
    Community Veteran Jun 22, 2015
    rikardo1979 , Jun 22, 2015 :
    @Manav Bhagia
    Is this a collection of yours or have you copied from elsewhere? if copied shouldn't you give credits?
    And how many of those have you actually tried yourself without causing any issues?
    What if this cause that some user going to end with non functional device? Shouldn't you have some disclaimer in your OP post?
    tandu and brolaire like this.
  18. Enyalius
    I placed maybe 70% of the tweaks in my build prop file earlier today (6 hours ago). No issues whatsoever. But I'm still sceptical as to what line does what and how it may affect the phone.
    #38
    rbagdai likes this.
  19. ddlittlejohn
    Honeycomb Jun 23, 2015
    ddlittlejohn , Jun 23, 2015 :
    Agree, kind of like the old days of busting out the hex editor on my computer to tweak the ram settings, some of these can quickly and easily cause problems. It would be great to at least know a little bit more about some of these
    #39
    tEf0o likes this.
  20. ddlittlejohn
    Which 70%??? :D
    #40
