18
Updated!Best build prop tweaks for your opo.
  1. Joyyy
    Jelly Bean Jun 23, 2015
    Joyyy , Jun 23, 2015 :
    This is dangerous stuff and only recommended for highly Advanced users.
    This should be written in first post, some of these can actually make it worse in another way
    #41
  2. Enyalius
    Enyalius , Jun 23, 2015 :
    See below
    # Saves some battery without reducing performances
    wifi.supplicant_scan_interval=497 (<=== THIS ONE I ALREADY HAD IN BUILD.PROP SO I ADJUSTED THAT FILE AND DIDN'T ADD THIS LINE - ELSE > DUPLICATES)
    pm.sleep_mode=1
    power.saving.mode=1
    ro.ril.disable.power.collapse=0
    ro.vold.umsdirtyratio=20
    # Misc Tweaks (enables ADB service)
    persist.service.adb.enable=1
    # Reduce dial-out time
    ro.telephony.call_ring.delay=0
    # Allow purge of assets to free more ram
    persist.sys.purgeable_assets=1
    # More free ram and apps load faster
    dalvik.vm.dexopt-flags=m=y
    # More RAM
    #persist.sys.purgeable_assets=1
    persist.service.pcsync.enable=0
    persist.service.lgospd.enable=0
    # Increase general Performance
    debug.performance.tuning=1
    # Increase some Performance
    ro.secure=0
    persist.sys.use_16bpp_alpha=1
    ro.product.gpu.driver=1
    ro.min.fling_velocity=8000
    # Reduce the black screen time of the proximity sensor
    ro.lge.proximity.delay=15
    mot.proximity.delay=15
    ro.ril.enable.amr.wideband=1
    # Better Scrolling responsiveness and speed
    windowsmgr.max_events_per_sec=150
    ro.max.fling_velocity=12000
    ro.min_pointer_dur=8
    # Smoothens UI
    ro.ril.enable.a52=1
    ro.ril.enable.a53=0
    # Increase camera's photo and video recording quality
    ro.media.dec.jpeg.memcap=8000000
    ro.media.enc.hprof.vid.bps=8000000
    ro.media.enc.hprof.vid.fps=65
    # Better Flashlight intensity and camera-flash quality
    ro.media.capture.flash=led
    ro.media.capture.flashMinV=3300000
    ro.media.capture.torchIntensity=40
    ro.media.capture.flashIntensity=70
    ro.media.capture.maxres=8m
    ro.media.capture.fast.fps=4
    ro.media.capture.slow.fps=120
    ro.media.panorama.defres=3264x1840
    ro.media.panorama.frameres=1280x720
    ro.camcorder.videoModes=true
    # Increase the volume steps in-call
    ro.config.vc_call_steps=20
    # Better call voice quality.
    # Improves Camera & Video Results
    ime_extend_row_keyboard=true
    ime_onehand_keyboard=true
    ime_split_keyboard=true
    ime_vibration_pattern=0:60
    # Disable Sending Usage Data
    ro.config.nocheckin=1
    # Miscellaneous Tweaks for performance
    ro.config.hw_menu_unlockscreen=false
    persist.sys.use_dithering=0
    ro.mot.eri.losalert.delay=1000
    # Better internet browsing & download speed
    net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960
    net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.umts=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.gprs=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.edge=4096,87380,256960,4096,163 84,256960
    net.tcp.buffersize.hspa=6144,87380,524288,6144,163 84,262144
    net.tcp.buffersize.lte=524288,1048576,2097152,5242 88,1048576,2097152
    net.tcp.buffersize.hsdpa=6144,87380,1048576,6144,8 7380,1048576
    net.tcp.buffersize.evdo_b=6144,87380,1048576,6144, 87380,1048576
    # Smoother video streaming and tweak media
    media.stagefright.enable-player=true
    media.stagefright.enable-meta=true
    media.stagefright.enable-scan=true
    media.stagefright.enable-http=true
    media.stagefright.enable-aac=true
    media.stagefright.enable-qcp=true
    media.stagefright.enable-record=true
    # 3G signal and speed tweaks
    ro.ril.hsxpa=2
    ro.ril.gprsclass=10
    ro.ril.hep=1
    ro.ril.enable.dtm=1
    ro.ril.hsdpa.category=10
    ro.ril.enable.a53=1
    ro.ril.enable.3g.prefix=1
    ro.ril.htcmaskw1.bitmask=4294967295
    ro.ril.htcmaskw1=14449
    ro.ril.hsupa.category=7
    ro.ril.enable.a52=1
    ro.ril.set.mtu1472=1
    persist.cust.tel.eons=1
    ro.config.hw_fast_dormancy=1
    # CRT
    persist.sys.screen_off=crt
    persist.sys.screen_on=none
    # Qualcomm tweaks
    com.qc.hardware=1
    debug.qc.hardware=true
    debug.qctwa.preservebuf=1
    debug.qctwa.statusbar=1
    # Enable Quick Power-On mode to reduce boot-time
    ro.config.hw_quickpoweron=true
    #42
    ddlittlejohn likes this.
  3. Manav Bhagia
    Ice Cream Sandwich Jun 23, 2015
    Manav Bhagia , Jun 23, 2015 :
    I've done just that
    #43
  4. ddlittlejohn
    Honeycomb Jun 23, 2015
    ddlittlejohn , Jun 23, 2015 :
    Cool, thanks.
    OP - would s good method to this be to take one section at a time, apply it, then reboot phone and test?
    #44
  5. leemartin
    Lollipop Jun 23, 2015
    #45
  6. bmark240
    bmark240 , Jun 23, 2015 :
    Please backup through TWRP before you try these settings....Also copy & paste the build prop file to another folder to replace before attempting any changes.
    YOU HAVE BEEN WARNED!!!
    #46
  7. joaofsa2000
    Gingerbread Jun 23, 2015
    joaofsa2000 , Jun 23, 2015 :
    can someonse make a zip file to apply these changes? because when i edit build.prop and then i save it says this file cannot be saved
    #47
  8. Enyalius
    Just copy your original build.prop file to your sdcard location, cause you can't be too careful. After that just adjust the build.prop in system/ and add all lines. That's how I did it, not one by one (too much rebooting :D)
    #48
  9. Enyalius
    Use ES File explorer or something like that and grant root access.
    #49
  10. joaofsa2000
    thats the problem i was using es explorer and i granted root access
    #50
  11. Manav Bhagia
    Use root browser
    #51
  12. joaofsa2000
    and when i paste those lines do i paste in the end with a space or just together. and do i paste exactly like in the thread? im still learning the android programing area so i dont understand this area good enough
    #52
  13. Manav Bhagia
    Paste exactly as in the thread
    Lines starting with # are just documenting lines like // in java
    #53
  14. joaofsa2000
    so in the end i leave a space before copying because i have some lines of viper4android and it has a space after them
    #54
  15. Manav Bhagia
    Not necessary
    #55
  16. Tarfex
    Ice Cream Sandwich Sep 6, 2015
    Tarfex , Sep 6, 2015 :
    So no problems with using some of them? I'm not a very experienced tweaker but I'm only going to use a couple of these, like making the flash light brighter or better internet and download speed. No side affects right?
    #56
  17. psiufoxx
    Cupcake Sep 9, 2015
    psiufoxx , Sep 9, 2015 :
    Just copy pasted every one of these into my build prop, and I'm typing from my OnePlus One right now. No problems at all. Youtube is working. All is buttery smooth!
    #57
  18. dinhvtai
    Froyo Nov 25, 2015
    #58
  19. Psk.it
    KitKat Nov 25, 2015
    Psk.it , Nov 25, 2015 :
    If use to add stylo-king settings, at the Last them has any effects
    #59
  20. Deactivated User
    Feb 12, 2016
    Deactivated User , Feb 12, 2016 :
    Using oxygen 2 on oneplus one ..
    LCD density settings are not there as in cyanogen
    hence using the following
    ro.sf.lcd_density=400
    some of them mentioned in the first list do not work on oxygen 2
    i tried crt no effect
    #60
