Updated issue via OnePlus 8T
  1. G1605347756215
    Cupcake Sep 12, 2021
    G1605347756215 , via OnePlus 8T , Sep 12, 2021 :
    After updating to 11.0.9.9 KB05DA in ONEPLUS 8T I am experiencing some issues in network and performance I think oneplus software update is getting worst everytime.
    I switched from Samsung to one plus thinking that I will the more comfortable with oxygen OS but now I think it was wrong. After every OS update I am a experiencing some issues like sometimes it drains more battery, experiencing heating issue, now i am facing the network problem and hangs most of the time.
    Hope Oneplus will solve this soon.
  2. pkg3107
    Ice Cream Sandwich Sep 12, 2021
    pkg3107 , Sep 12, 2021 :
    After an update, give a few days time to the device in order to optimise the usage pattern and adjust battery usage accordingly.
    Meanwhile, you can try clearing the cache of the device.
    If you can elaborate on what performance issues you are facing, I can try to help
    Gor., G1605347756215 and rHITkM. like this.
  3. G1605347756215
    Cupcake Sep 13, 2021
    G1605347756215 , via OnePlus 8T , Sep 13, 2021 :
    Sometimes it automatically freeze, that time fingerprint doesn't work, everytime i need to restart my mobile to use internet..
  4. BetaBot
    Jelly Bean Sep 13, 2021
    BetaBot , Sep 13, 2021 :
    Try to clear unnecessary apps running in the background. Also do clear cache/data of the respective app which is getting freezed.
    For finger print to work i dont think you need to restart. Give the digits for unlock and next time it should work fine
    G1605347756215 likes this.
  5. pkg3107
    Ice Cream Sandwich Sep 13, 2021
    pkg3107 , Sep 13, 2021 :
    If the fingerprint issue is while using AppLock, the issue is being faced by many. You can try waiting for a few updates, hoping it will be resolved.
    Gor. and G1605347756215 like this.
  6. psygarden
    OnePlus TV Product Ninja 2021 Sep 13, 2021
