553
[Updated]OxygenOS 5.1.9 OTA for the OnePlus 6
  1. Joakim_Borgström
    Cupcake Jul 17, 2018
    Joakim_Borgström , Jul 17, 2018 :
    Well Google is a friend sometime, multiple users had issue with OnePlus 6 devices (and other Android devices) where audio is missing on all incoming calls, confirmed with OnePlus support as well. Only working solution was to use audio route to solve the issue, but many users with the red version the audio route workaround doesn't work unless we installed Android P where you are able to disable the 3 virtual USB sound devices, then audio route works. That is why I dropped the question here in the forum to see if any more users tried it and solves the audio route issue.
  2. G_Rich_Cowan_EQlj
    Gingerbread Jul 17, 2018
    R1530620330308 and KeithW8 like this.
  3. FaleshC
    KitKat Jul 17, 2018
    FaleshC , Jul 17, 2018 :
    i m sure someone will get back to you with the answer.
  4. Chinaroad
    Honeycomb Jul 17, 2018
    Chinaroad , Jul 17, 2018 :
    here it is
  5. jd2016
    jd2016 , Jul 17, 2018 :
    I was literally wanting to throttle oneplus's neck with the extreamly slow updates . but now I feel Alot happier .
    i have even put my OnePlus 6 up for sale on my local and site cus I'm fed up with a rubbish buggy phone .
    hope this fixes Alot of issues .
  6. Jorma Kari
    Eclair Jul 17, 2018
  7. pds_sohi
    pds_sohi , Jul 17, 2018 :
    what about battery drain???? last Hydrogen update addressed drain issue...wht about us??
  8. atmsriram
    atmsriram , Jul 17, 2018 :
    sleeping stand by mode also added but missing in the change log I feel it's best future who use the mobile ones in hours great one plus good work
  9. RapStar
  10. Mange80
    Ice Cream Sandwich Jul 17, 2018
  11. FaleshC
    KitKat Jul 17, 2018
    hehehe they will start updating 6 when they release op7, this is their history and tactics, release new device and update old device faster to keep the customers mouth shut...and avoid uproar in community.
    ok but, you can see 3/T and 5/T gets updates for everything for testing... purpose because they have beta program..
    Riju Ghosh8653 likes this.
  12. hgk2011
    Eclair Jul 17, 2018
    hgk2011 , Jul 17, 2018 :
    I updated to 5.1.9 but Roaming is not working for me, my sim cards not showing roaming symbol
  13. kspn
    Donut Jul 17, 2018
  14. A1527233227732
    Froyo Jul 17, 2018
  15. siva141
    Eclair Jul 17, 2018
  16. fidus62
    Jelly Bean Jul 17, 2018
  17. NoInspiration
  18. Mange80
    Mange80 , Jul 17, 2018 :
    There is no battery drain isues
  19. Mange80
    Try a restart with clear cache
  20. siva141
    Eclair Jul 17, 2018
    siva141 , Jul 17, 2018 :
    i asked that battery drain issue cleared or not in this update
    A1527233227732 likes this.
