552
[Updated]OxygenOS 5.1.9 OTA for the OnePlus 6
  1. Vishal_panch
    Donut Jul 31, 2018
    Vishal_panch , Jul 31, 2018 :
    Try again from the edge...It is working.
  2. aksiraj
    Donut Jul 31, 2018
    aksiraj , Jul 31, 2018 :
    what..?which side...can u give me screenshot...
  3. heartless28
    Gingerbread Jul 31, 2018
    vriesdejoop likes this.
  4. vriesdejoop
    Ice Cream Sandwich Jul 31, 2018
    vriesdejoop , Jul 31, 2018 :
    heartless28
    ok smart kid.​
    not ment to be smart, gave the advice myself a lot of time on previous OP phones, was always a very good advice, but now with the seamless update system it has no use anymore....
  5. leoelsa11122
    Cupcake Jul 31, 2018
    leoelsa11122 , Jul 31, 2018 :
    I'm facing a problem with the slide bar. After slides to vibrate, I still receive a call ring. I check the settings find the volume set as 14% and the volume key is out of function. Then I try to set the slide bar back to"Ring" and set to "Vibrate" again. The ring volume become zero.
    Anyone facing thesame?
  6. dec1153
    Honeycomb Jul 31, 2018
  7. fidus62
    Jelly Bean Jul 31, 2018
    fidus62 , Jul 31, 2018 :
    Is that your name? Hi battery, nice to meet you... :)
    tigerstrom and dec1153 like this.
  8. sameer@123
  9. fidus62
  10. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Jul 31, 2018
  11. sameer@123
  12. Vishal_panch
    Donut Jul 31, 2018
  13. K1531063395848
  14. B1530907660756
    B1530907660756 , Jul 31, 2018 :
    Goto settings and the system update. Here you can check if the update is available for you. As soon as it is, you just have to click update now.
  15. Cervantes
    Lollipop Moderator Jul 31, 2018
    Cervantes , Jul 31, 2018 :
    Please read the first post
    Thread merged
  16. Elaitscha
    Eclair Jul 31, 2018
    Elaitscha , Jul 31, 2018 :
    wiping cache is not usefull cause in the one plus 6 partition there is no cache to wipe.
  17. Saurabhshukal149
    Donut Jul 31, 2018
    Saurabhshukal149 , Jul 31, 2018 :
    Please improve battery life whether Wi-Fi or data network is connected and not to take more battery life... In sleeping mode why is battery draining. Come on Please do something . We request add more gestures like quick ball .
  18. Deactivated User
    Jul 31, 2018
    Kytharsis and Vishal_panch like this.
  19. Vishal_panch
    Donut Jul 31, 2018
    csiemers
    If your phone is turned on it is going to use battery, so "sleep mode" is still going to drop a few percent at night. I believe mine goes down 5-8% which seems fairly normal from what I've seen others say.​
    How much screen on time do you get?
  20. Z1533052961612
    Z1533052961612 , Jul 31, 2018 :
    hi guys
    post updating my one plus 6 to oxygen 5.1.9 the battery life has gone considerably low. Full charged phone now lasts for less than 7 hours
    Also I keep getting messages about Potential Heating Issue being caused by various apps.
    Anyone else facing same issue??
    Vishal_panch likes this.
