553
[Updated]OxygenOS 5.1.9 OTA for the OnePlus 6
  1. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Aug 6, 2018
    KeepTransisting , Aug 6, 2018 :
    That's the catch, though. advanced optimizations makes background apps not use background data / battery. Now, what you can do is enable the advanced optimizations, but for Gmail set it to "don't optimize"
    nacofficial222 likes this.
  2. H1533571235760
    Cupcake Aug 6, 2018
    H1533571235760 , Aug 6, 2018 :
    Hi one plus team,
    I'm facing network and call drop issues. and also not getting calls instead getting missed calls which is very annoying.
    few of my friends who bought the phone also having the same problem.
    please let us know when will be the next update for resolving this issue.
    please sort this out as soon as possible
  3. V1528906791331
    Cupcake Aug 6, 2018
    V1528906791331 , Aug 6, 2018 :
    sure, that is an option. although, Gmail doesn't feature on the damn list -_-
    All (or most) unwanted Google features are listed, but for Gmail!
  4. Fauert
    Honeycomb Aug 6, 2018
    Fauert , Aug 6, 2018 :
    You have upgraded to "ANDROID P BETA" . READ BETA ! No one have yet said it's for users who do not know, what they are doing !
    Rollback too official firmware, do a factory reset, you are good to go on fresh and shiny !!
    Vilfy likes this.
  5. Sjansari
    Donut Aug 6, 2018
  6. Savendra
    Donut Aug 6, 2018
  7. KeepTransisting
    16:9, just like 19:9, cuts off the top and bottom of the camera sensor. Your best bet is to either:
    1) Capture in 4:3 and crop them yourselves
    2) Use a different camera app that allows 16:9
  8. Savendra
    Donut Aug 6, 2018
    Savendra , Aug 6, 2018 :
    But better than 19:9 and from other app quality is not good as stock camera
  9. hibirendra1
    Cupcake Aug 6, 2018
  10. KeepTransisting
    Try Camera FV5. Much better quality than the stock camera, in my opinion
  11. G_roshan_james_qPum
    Cupcake Aug 6, 2018
  12. prabhattomar
    prabhattomar , Aug 6, 2018 :
    what kind of malfunction can u tell I'm about to update
  13. fidus62
    Jelly Bean Aug 6, 2018
    fidus62 , Aug 6, 2018 :
    Good luck my friend...
  14. G_GhOsT_EvErYwHeRe_VWry
    Cupcake Aug 6, 2018
    G_GhOsT_EvErYwHeRe_VWry , Aug 6, 2018 :
    bro i m use all types of phone, & fixed all problem by myself, i m rooted my moto e & use all rom . plz don't think i Don't know about anything. but this phone i m buying few days ago, & face this type of problem that why i m posting thsi.
  15. bittss2
    Froyo Aug 7, 2018
    bittss2 , Aug 7, 2018 :
    5.1.6
    I personally find it very much stable.
  16. bittss2
    Froyo Aug 7, 2018
    1st of all check your preferred network type. It should be 2g/3g/4g automatic.
    2nd, enable dual 4g network
    3rd, enable volte on each sim
    If these 3 measures dont work for you, wait for an OTA. Till then u dont need to restart your phone. Just switch on nd off flight mode. Your 4g network will come up.
  17. sanket2u2
    Froyo Aug 7, 2018
    sanket2u2 , Aug 7, 2018 :
    is it just me or others also feel that camera color accuracy and overall picture quality has gone down post this update...
  18. rohitsharma_j22
    Gingerbread Aug 7, 2018
    rohitsharma_j22 , Aug 7, 2018 :
    Hi,
    There is Bluetooth Audio Codec setting in Developer Option. By default, "Use system selection" option is selected. Now, If i change the codec to any other option and left the setting, then it again selecting the default option. Never staying on manually selected option. Can anyone elaborate why is this so???
  19. Emmi777
  20. rohitsharma_j22
    I suppose around November end or December Start.
