552
[Updated]OxygenOS 5.1.9 OTA for the OnePlus 6
  1. abhijai07
    Cupcake Jul 21, 2019
    abhijai07 , Jul 21, 2019 :
    settings > utilities > parallel apps
  2. Chakri12
    Chakri12 , Jul 21, 2019 :
    I did that.i on dual what's app but same account is showing in both applications.not only what's app all app are like that only
  3. abhijai07
    Disable the parallel apps restart your phone. enable the parallel apps again try login with different accounts. Hope it'll work
  4. Chakri12
    I did but not working
  5. abhijai07
  6. Chakri12
  7. abhijai07
    souravd09@ likes this.
  8. Chakri12
    after update this is not working not last update.before last update onwards I am facing this problem
  9. abhijai07
    You should be having recent patch of 9.0.7
  10. Chakri12
  11. Chakri12
    i am using 9.0.7 only
  12. Chakri12
  13. Chakri12
  14. abhijai07
  15. Chakri12
    1st I am using 2 different accounts in my phone but one day suddenly same account is appearing both what's apps
  16. abhijai07
    Disable the parallel apps> wipe the cache data > restart> Enable the parallel apps. This might work.
  17. Chakri12
    now wat can I do
  18. Chakri12
    how can wipe the cache data
  19. abhijai07
    Hold the power button for. couple of seconds > recovery> enter your pattern > wipe data> Enter > Ok
  20. Chakri12
    any data will erase from my phone
