Upgradation of OS
  1. apollobiswas
    Eclair Jun 10, 2016
  2. Jitesh Saitawadekar
    KitKat Jun 10, 2016
    Jitesh Saitawadekar , Jun 10, 2016 :
    Please provide more details on which OOS version you are on?? And have you received OTA or no??
  3. apollobiswas
    Eclair Jun 10, 2016
  4. ravi.leo1012
    Gingerbread Jun 10, 2016
    ravi.leo1012 , Jun 10, 2016 :
    Then just click the INSTALL/DOWNLOAD button and phone will do the rest. You must have decent battery life or plug in the charger as it will download 1.1GB and then it will process the installation.
    All the best. :)
    apollobiswas likes this.
  5. Jitesh Saitawadekar
    KitKat Jun 10, 2016
    Just make sure all the google apps are enabled before installing that ota and take a backup of your contacts on gmail so that you can have a backup & then install it.
  6. chris_wds
    Honeycomb Jun 10, 2016
  7. apollobiswas
    Eclair Jun 10, 2016
  8. Jitesh Saitawadekar
    KitKat Jun 10, 2016
    Wow you are rooted and you don't know to install an update??? o_Oo_O
    Anyways just go to Settings > Apps > Three dots above click on that > Reset App Preferences which will enable every disabled app & if you are rooted than OTA won't install so make sure you remove root before install.
    ravi.leo1012 likes this.
  9. ravi.leo1012
  10. flobengogen
    Ice Cream Sandwich Jun 10, 2016
    flobengogen , Jun 10, 2016 :
    u cant install otas if u r rooted. ull have to wipe ur phone then flash the os zip along with gapps
  11. Jitesh Saitawadekar
    KitKat Jun 10, 2016
    Gapps??? :eek::eek::eek::eek: Where did it came from ???o_Oo_Oo_O
  12. apollobiswas
    Eclair Jun 10, 2016
    apollobiswas , Jun 10, 2016 :
    ro
    rootted means I bought this from china with buildin Hydrogen OS. I have changed it to oxygen OS following instruction in this page. That's it. is it called rooted??
  13. jkb114
    Lollipop Jun 10, 2016
    jkb114 , Jun 10, 2016 :
    Easy way to tell if you are rooted... Do you have an app called SuperSU or similar?
    Jitesh Saitawadekar likes this.
  14. apollobiswas
    Eclair Jun 10, 2016
  15. Jitesh Saitawadekar
    KitKat Jun 10, 2016
    :sweatsmile: Than you have not rooted it seems just normally install OTA but do what i said reset app preferences.
  16. jkb114
  17. apollobiswas
    Eclair Jun 10, 2016
  18. jkb114
  19. apollobiswas
    Eclair Jun 10, 2016
  20. jkb114
    So you aren't rooted. Just install the OTA as per normal procedure.
    Backup everything
    Settings
    System Updates
    Install
