Urgent! Help with the MSM tool (stuck in Param preload)
  1. H1550749123362
    Cupcake Sep 23, 2019
  2. tommygooden
    Eclair Sep 23, 2019
    tommygooden , Sep 23, 2019 :
    I think the people who are able to help will need to know which OP device you are running. I'm not sure. Just assuming.
  3. Cervantes
    Lollipop Moderator Sep 23, 2019
    Cervantes , Sep 23, 2019 :
    Hi
    gives you some error message
    do not open msntool until the end and with administrator rights
  4. Polloux
    Donut Sep 23, 2019
    Polloux , Sep 23, 2019 :
    i have the same problem triying to install twrp in Android 10, tried in different PC and nothing, the param stuck remain, luckly my brick was in the bootloader. I do a flash-all-partitions.bat in a stock fastboot rom and problem solved. I hope this can be used in your case.
  5. SpinSupreme
    Cupcake Oct 2, 2019
