URGENT- Oxygen OS flashable - (with flashall.bat)
  1. ravismiles4u
    Ice Cream Sandwich Jan 8, 2016
    ravismiles4u , Jan 8, 2016 :
    Dear Gurus,
    Can someone provide me the link to download Oxygen OS. So, that I can flash without any custom recovery.
    I want to get my phone back to the company provided one...
    This is because my phone is not working.. it is only able to go to fastboot mode...
    Please help urgent.....
    Thanks a ton
  2. camohan
    Assistant Head Moderator Assistant Head Moderator Jan 8, 2016
    camohan , Jan 8, 2016 :
    https://forums.oneplus.net/threads/...ed-op2-oxygenos-2-1-1-fastboot-images.388967/ You can refer this thread. It is suggested to ask follow up question on that thread only.
    PRK.R and ravismiles4u like this.
  3. anupritaisno1
    KitKat Jan 8, 2016
    anupritaisno1 , Jan 8, 2016 :
    Pm me with your timezone information and then I'll help
    The method I use works perfectly but erases data
    ravismiles4u likes this.
  4. ravismiles4u
  5. ravismiles4u
    Thank you!
  6. Naman Bhalla
    Recognized developer Recognized Developer Jan 8, 2016
    Naman Bhalla , Jan 8, 2016 :
    First check if the bootloader is still unlocked ? If yes, then follow the last page of my fastboot images thread. If no, then follow the first page of my Mega Unbrick Guide Thread
    Sir. Why wipe data at all ?
    PRK.R likes this.
  7. ravismiles4u
    I'm trying for MEGA unbrick guide... because my phone is not unlocked. even if I try to do unlock then phone is going crazy.
  8. ravismiles4u
    Bro! it is not working ....
  9. Eshan_Anand
  10. Jeffreyvdv3lde
    Jelly Bean Jan 8, 2016
  11. ravismiles4u
    I ran as administrator ... but the same issue.
    my phone only starts on fastboot mode. It is not rebooting/not even going into recovery mode.
  12. LiFeLeSSLeGeND
    Honeycomb Jan 8, 2016
    LiFeLeSSLeGeND , Jan 8, 2016 :
    Like @Naman Bhalla you have to have fastboot and adb installed on your computer before proceeding to fastboot flash anything.
  13. ravismiles4u
    My issue is bootloop issue... and it is not even going into recovery
    My device is locked and when I try to unlock it is going to bootloop.
  14. inffy
    KitKat Jan 8, 2016
    inffy , Jan 8, 2016 :
    As clearly already stated you don't have the files in the same directory as your fastboot&adb executable files. They have to be in the same directory or you have to add your directory to your Windows PATH variable
    allenlau and PRK.R like this.
  15. Metamist
    Donut Jan 8, 2016
    Metamist , Jan 8, 2016 :
    Install the Android SDK which will automatically add adb and fastboot to your PATH, then you can use the fastboot command. Alternatively, if the SDK did not add it to the PATH, you have to run the files where adb.exe and fastboot.exe is located.
  16. ravismiles4u
    Ice Cream Sandwich Jan 11, 2016
    ravismiles4u , Jan 11, 2016 :
    My ADB and FASTBOOT files are in the same directory. Here the problem is not with Windows.
    Problem is with my phone which has bootloop problem and the funniest part is it is not unlocked which is blocking me to flash custom recovery. It is too bad ... no other option left for me.
  17. U1631184521109
    Cupcake Sep 9, 2021
    U1631184521109 , Sep 9, 2021 :
    I am in exactly the same position. Did you resolve this? (Son is desperate for his 'new' phone)
