70
[USA and Canada] 100 OxygenOS Delights Scavenger Hunt
  1. cdnfarmer
    KitKat Nov 26, 2019
    Stickied Post
    cdnfarmer , Nov 26, 2019 :
    How you can use a fast and short downwards swipe to close the picture you are looking at and return to the folder; i.e minimize the view
    A similar action works in you tube. So if someone is watching a video they can anywhere on it scroll down to minimize it.
    #81
  2. cdnfarmer
    KitKat Nov 26, 2019
    Stickied Post
    #82
  3. shiftdel
    Eclair Nov 26, 2019
    #83
  4. cdnfarmer
    KitKat Nov 26, 2019
    Animation when click on a box to enter text and the keyboard appears from the bottom.
    #84
    MosheG1 likes this.
  5. MosheG1
    Jelly Bean Nov 26, 2019
    MosheG1 , via OnePlus 7 Pro , Nov 26, 2019 :
    this was done already
    this isn't an oxygen os function, this is a chrome feature
    also a chrome feature by Google not OnePlus
    #85
  6. cdnfarmer
    KitKat Nov 26, 2019
    Stickied Post
    If there is a problem with the WiFi connection or a new connection requires login or a WiFi is detected, the WiFi icon has an exclamation mark to the right of it. L
    Note:s the location is shown on the image but there are no issues or new WiFi here so no exclamation point.
    #86
    MosheG1 likes this.
  7. MosheG1
    #87
  8. cdnfarmer
    KitKat Nov 26, 2019
    Stickied Post
    If on LTE or 4G network, it appears above the mobile data in the top right corner.
    #88
    MosheG1 likes this.
  9. MosheG1
    Jelly Bean Nov 27, 2019
    Stickied Post
    #89
  10. cdnfarmer
    KitKat Nov 27, 2019
    cdnfarmer , Nov 27, 2019 :
    Thanks. I know. I was the first to post it and hence the stickied post. ;)
    thanks for the feedback.
    You are pretty good at finding lots and keeping up. Good job.
    #90
    MosheG1 likes this.
  11. huxley1t
    Gingerbread Nov 27, 2019
    #91
    cdnfarmer likes this.
  12. MosheG1
    MosheG1 , via OnePlus 7 Pro , Nov 27, 2019 :
    thanks
    #92
  13. MosheG1
    here's another one, when you pull down the pull-down menu the icons for your notifications shift over to the left and then if you continue to pull they split into their individual notifications
    #93
  14. cdnfarmer
    KitKat Nov 27, 2019
    In the memo in the shelf, in edit mode
    1. There are several icons on the right, the pin is greyed out. When you click on it, it turns white.
    2. A message then appears saying "This note is pinned" Screenshot_20191126-171615.jpg
    3. If you deselect the pin icon, the icon turns grey AND another message appears at the bottom saying " this note is unpinned". Screenshot_20191126-171555.jpg
    #94
    MosheG1 likes this.
  15. cdnfarmer
    KitKat Nov 27, 2019
    Navigating between the shelf and apps using the navigation buttons. If in an app then access the shelf. When click recent app button, it brings you to the last used app, click the same button and it activates or opens that app. Click on the home button and it returns you to the shelf. Once on the shelf, click home button to access the home page.
    #95
    MosheG1 likes this.
  16. cdnfarmer
    KitKat Nov 27, 2019
    I'm the notification area. For a sms, can click "reply via sms" so you don't need to open the app. Screenshot_20191126-173457__01.jpg It can be done right there without navigating away from what you were doing. AND
    The send icon is greyed out until text is written then it changes colour.
    #96
    MosheG1 likes this.
  17. cdnfarmer
    KitKat Nov 27, 2019
    Can close all notifications at once with the icon at the bottom with multiple lines. Screenshot_20191126-174259__01.jpg
    #97
    MosheG1 likes this.
  18. cdnfarmer
    KitKat Nov 27, 2019
    When you scroll to the bottom of the notification list, "manage notifications" appears and then it list all apps and which to display. Screenshot_20191126-174259__02.jpg
    Can select to display then the button shows in colour and when the app notifications is turned off then the button is greyed out (think @MosheG1 mentioned a similar functions but in another area, so here I'm talking about the manage notifications feature).if acceptable because different area great but please don't get mad if it is counted the same and why I highlighted it was mentioned for other parts of the OOS. Wanted to show what happens when you use that feature.
    #98
    MosheG1 likes this.
  19. cdnfarmer
    KitKat Nov 27, 2019
    In OnePlus photo gallery>edit>add a brush stroke, two curve arrows appear to undo and redo
    #99
    MosheG1 likes this.
  20. cdnfarmer
    KitKat Nov 27, 2019
    OnePlus Photo Gallery
    When a folder is empty and then its opened, the user gets a picture and "inspirational" quote
    MosheG1 likes this.
