VoreDock , via OnePlus 9 Pro , Jan 18, 2022 : I installed update c41 from color OS on my OnePlus 9 pro last night I love it it works great I have one issue though I've been able to get everything to work the way it should except for SMS messages every time I send an SMS message a pop up appears that says "messages will send an SMS message to..." Whatever number I'm sending and I have to press okay and then it sends the message anybody know how to get rid of that pop up?
VoreDock , via OnePlus 9 Pro , Jan 18, 2022 : Well I partially found a fix I was forced to use the built-in messenger app arently that's the only thing you can properly use SMS messages with if anyone knows a workaround from China please share
Ultradyong , via OnePlus 9 Pro , Jan 19, 2022 : It seems to only work in China only, because it doesn't seem to work for me too. I only get this issue in HeyTap Cloud support and the device is asking for sim authorization on device.
VoreDock , via OnePlus 9 Pro , Jan 20, 2022 : I was able to do the hay tap cloud by going to the website and setting up a account but I still can't used a 3ed party text client without the pop-up constantly coming up it will still work and send the text it's just the pop-up comes up every time and ask me to confirm if I want to send
VoreDock , via OnePlus 9 Pro , Jan 20, 2022 : I found a workaround a app called YAATA https://play.google.com/store/apps/details?id=rpkandrodev.yaata Sms/MMS app that lest you send all messages in MMS
Q1637502072463 , via OnePlus 9 Pro , Jan 26, 2022 : Please give me the link. I'm using 9 pro Chinese. I want to install color os 12.
Ultradyong , via OnePlus 9 Pro , Jan 26, 2022 : Go to your device run auto update or trial version, you will then choose to run trial version if you wish to install official color os 12 on your device.
