usage and diagnostics feature via OnePlus 6T
  1. Sayandeep Mondal , via OnePlus 6T , Apr 9, 2020 :
    Hi friends hope you all are good and health in your home . I opened the settings→privacy ,and found the option“ usage and diagnostic ” which was on by default settings .
    It is actually a feature which transfer your data to google for better performance and better Android experience. I want to know that should I leave it on or off and does it not safe to share your data to google?
  2. Caomhin
    Lollipop Apr 9, 2020
    Artemus. likes this.
  3. Sayandeep Mondal , via OnePlus 6T , Apr 9, 2020 :
    will it make any problem if i turned it off
  4. Caomhin
    Caomhin , via OnePlus 6T , Apr 9, 2020 :
    No there will be no problem, it just won't send the data to Google
  5. #5
  6. Caomhin
    No, it will make absolutely no difference
  7. #7
    Caomhin likes this.
