USB C earphone activation for OP 5T
  1. D1533851859593 Eclair Jun 19, 2019
    D1533851859593, Jun 19, 2019 :
    please can someone guide me how to activate a random USB C earphone in my OnePlus 5T.
    I have tried in watching YouTube but most of them about OnePlus 3/3T
    even though I tried them on my OP 3 , nothing happened, no sound heard.
    I can only hear from the speakers even the USB earphone is attached.
    are there any specific condition that it has to be OnePlus bullets?
    please anyone help me
  2. Waveform Modifier Marshmallow Jun 19, 2019
    Waveform Modifier, Jun 19, 2019 :
    Turn on OTG.
  3. D1533851859593 Eclair Jun 19, 2019
  4. The1Lion Lollipop Jun 19, 2019
    The1Lion, Jun 19, 2019 :
    are you sure the headphone/ear piece actually works? sounds like it not recognized at all.
  5. D1533851859593 Eclair Jun 20, 2019
    D1533851859593, Jun 20, 2019 :
    how to test it
    [e]1f612[/e]
  6. D1533851859593 Eclair Jun 21, 2019
    D1533851859593, Jun 21, 2019 :
    could you someone please assist me how to test a random USB c earphone with OP5T
  7. borft Jelly Bean Jun 22, 2019
    borft, Jun 22, 2019 :
    what do you mean by random? you want us to help you pick a random headset?
  8. Nick 59 Lollipop Jun 22, 2019
    Nick 59, Jun 22, 2019 :
    Really?
    Try with another device!
  9. Rk181997 Froyo Jun 22, 2019
    Rk181997, Jun 22, 2019 :
    turn on UDB DEBUGGING options in DEVELOPERS OPTIONS.
    if haven't enabled DEVELOPERS OPTIONS, enable it tapping BUILD NUMBER 5 to 7 times. then you can find the Developer Options in Advanced-> Developers Option
  10. D1533851859593 Eclair Jun 23, 2019
    D1533851859593, Jun 23, 2019 :
    yes, it's just a unspecified USB c earphone.... that's what I meant
  11. D1533851859593 Eclair Jun 23, 2019
    nothing working....
    I have tried from the beginning....
    is there any tweaks to be done in addition?
  12. Waveform Modifier Marshmallow Jun 23, 2019
    Waveform Modifier, Jun 23, 2019 :
    Maybe use a headphone with a 3.5 jack instead. Less headaches.
  13. Meherbanali Froyo Jun 25, 2019
    Meherbanali, Jun 25, 2019 :
    It means that earphones are not working.
  14. D1533851859593 Eclair Jun 25, 2019
    D1533851859593, Jun 25, 2019 :
    it's brand new , I bought it through eBay
  15. borft Jelly Bean Jun 26, 2019
    borft, Jun 26, 2019 :
    so it a usb audio device? or does it use audio over usbc? because the latter will never work.
    eye842 likes this.
  16. D1533851859593 Eclair Jun 26, 2019
    D1533851859593, Jun 26, 2019 :
    I can't really differentiate this issue
    how?
  17. borft Jelly Bean Jun 26, 2019
    how should I know? read the manual, Google it, take the device a part... ;)
  18. OnePlus OxygenOS Honeycomb Jun 27, 2019
    OnePlus OxygenOS, Jun 27, 2019 :
    USB C to 3.5 converter [e]1f602[/e]
  19. Waveform Modifier Marshmallow Jun 27, 2019
    Waveform Modifier, Jun 27, 2019 :
    Why would one need that for the 5/5T? That seems kind of stupid...no?
    borft likes this.
  20. borft Jelly Bean Jun 27, 2019
    borft, Jun 27, 2019 :
    in the case the headset is not really an active headset, meaning it uses audio over usb. the 5t does not support that, as it has a 3.5mm jack for analog audio output. cheaper headsets usually don't have a proper active DAC built-in
