USB-C Headphones - do they work oob ?
  1. subashchandran
    Eclair Dec 17, 2017
    subashchandran , Dec 17, 2017 :
    I have 2 USB-c headphones and both of them dont work out of the box on the OnePlus5T. The Xiaomi ANC headphones will work but I had to turn OTG on in settings for it to work. The Le-Eco one didnt work period..with or without OTG.
    This needs to be fixed as more and more ppl are buying/using USB-C headphones. The experience has to be that when you plug-in a USB-C headphone it should just work.. just as you would expect from a 3.5mm jack headphone.
    Im on OOS 4.5.4
  2. Xavierpony
    Gingerbread Dec 18, 2017
    Xavierpony , Dec 18, 2017 :
    why did you buy a USB c headphone. like really the only reason to buy is if a phone doesn't have a 3.5mm jack. and then most people use Bluetooth.
    ibobcey likes this.
  3. ibobcey
    Cupcake Dec 18, 2017
    gotshoaib likes this.
  4. F_Yannik_Luca_nKvK
    Cupcake Dec 20, 2017
    F_Yannik_Luca_nKvK , Dec 20, 2017 :
    I just recently bought Type C Headphones from Xiaomi with noice cancelling. Everything works fine, only the microphone and skipping to the next track wont work. I have an OnePlus 3 with Android 8... Hope you can fix that with an update. Its very annoying
