Usb c otg adaptor for sound enhancement
  1. Amanrae
    Honeycomb Aug 27, 2018
    Amanrae , Aug 27, 2018 :
    Hi,
    I want to ask if anyone is using USB C to 3.5 mm adapter for better sound output over OTG on OP 6?
    I found Moshi adapter on Amazon.in which supports DAC and better than CD sound quality.
    P.S. - I am using premium Sony earphones, though the sound clarity is good but on OnePlus 6 there is too much loss and distortion.
  2. nabbed
    nabbed , Aug 27, 2018 :
    Two questions:
    1) Why do you think that the USB-C port has the capability to output sound via an adapter, when the phone already has a 3.5mm jack?
    2) What is the impedance of your Sony headphones? The OP6 3.5 mm jack does not have a lot of power to drive high quality headphones, though my 300ohm Sennheiser HD650 do sound excellent through the headphone jack, just quiet.
  3. Amanrae
    1). There is someone in the community who posted that a Htc dongle did work for him on his OP6 and the sound quality improved a lot.
    2). I have earphones whose impedance is around 32 ohms.
  4. AlouLouky
    KitKat Aug 30, 2018
    AlouLouky , Aug 30, 2018 :
    Android supports audio over usb one versions 5.1 abd after.You can conect an external DAC and do the audio processing outside the Phone.
    Amandaral likes this.
  5. Jaws4God
    Froyo May 14, 2019
    Jaws4God , May 14, 2019 :
    does anyone know how to make USB audio work for Car Radio's ? (pioneer) I plug mine in to use WAZE.. and the map shows on the pioneer.. but all audio is still coming out of my OP6 speaker.. Thanks!
  6. Artemus.
    Community Hero 2020 May 14, 2019
    Artemus. , May 14, 2019 :
    Enable OTG.
    Jaws4God likes this.
  7. Jaws4God
    Froyo May 14, 2019
    I was thinking I had seen this before and tried to enable it.. I do not believe it worked.. unless you have to do something else along with enabling OTG? but i can try again. thanks!
  8. AlouLouky
    KitKat May 15, 2019
    AlouLouky , May 15, 2019 :
    YES enable OTG via menu,also if there is no activity OTG gets disabled and you have to re-enable!
