6
USB C to 3.5 mm headphone jack adapter.
  1. Sorigo
    Gingerbread Jun 5, 2019
    Sorigo , Jun 5, 2019 :
    Hi,
    Does this adapter work? How's the sound quality? What are the alternatives?
    Thanks.
  2. Rajan183
    Donut Jun 5, 2019
  3. bacon612
    Cupcake Jun 6, 2019
    bacon612 , Jun 6, 2019 :
  4. bacon612
    Cupcake Jun 6, 2019
    Which model adapter are you using? I just got the Apple USB-C to 3.5 headphone jack adapter and its not working with my op7 pro. Ive tried toggling USB OTG also and no joy.
  5. Sorigo
    Gingerbread Jun 9, 2019
    Sorigo , Jun 9, 2019 :
    Besides OnePlus adapter, which is compatible?
    I order from Amazon one that has USB C to 3.5 and a charging ability, bit it doesn't work for sound. What are the requirements for the adapter to work with OnePlus 7 Pro?
    Thanks.
  6. J1559934403192
    Cupcake Jun 9, 2019
    J1559934403192 , Jun 9, 2019 :
    Does the USB C to 3.5mm headphone jack of any company other than OnePlus works with the device... I'm having OnePlus 7
  7. Nick 59
    Marshmallow Jun 9, 2019
    Nick 59 , Jun 9, 2019 :
    Yes. They are all essentially just a few wires but Oneplus' is red.
    Pratheekh Chandra likes this.
  8. J1559934403192
    Cupcake Jun 9, 2019
    But after reading the reviews i came to know that the usb c to headphone jack is a terrible experience with every user, even with OnePlus adapter... What should I do? I've bought a new pair of earphones few days back but unable to use them after buying OnePlus 7
    Shalin235 likes this.
  9. dixiko
    Cupcake Jun 9, 2019
    dixiko , Jun 9, 2019 :
    Hi. Does anybody know if there's a USB-c to Jack + charge compatible with warp charge?
  10. Nitin1plus72
    Cupcake Jul 25, 2019
    Nitin1plus72 , Jul 25, 2019 :
    Same here...The c to aux connector plays sound but doesn't receive Audio from mic.
    Brian creighton likes this.
  11. N1564148603614
    Cupcake Jul 26, 2019
  12. Brian creighton
    Cupcake Jul 29, 2019
    Brian creighton , Jul 29, 2019 :
    I bought apple usb-c headphones jack adapter, the sound quality is fine, but the volume does not go above about 70%,I am very disappointed as I thought the audio would have been great, I turned the audio warning off, thinking this would have brought the sound up to 100 %.. If anyone knows a way round this i would be very grateful.. P. S. I am not a tech expert
    V1572885054642 likes this.
  13. Shalin235
    Gingerbread Jul 29, 2019
    Shalin235 , Jul 29, 2019 :
    Talking about my experience recently ordered oneplus type c to 3.5mm jack and i found it works perfect but what lacks is the quality of sound too high treble sounds on headphones and no bass at all its too punchier treble and you feel like not to listen through it.
    The mobile lacks bass quality which is needed with utmost priority.
    Using Sennheiser cx275s.
    hope they come up with fix in next update.
  14. Dr._Shubham_Sharma
    Cupcake Aug 3, 2019
    Dr._Shubham_Sharma , Aug 3, 2019 :
    Nope, none of them supports current over 1.5 Amp.
    dixiko likes this.
  15. Dr._Shubham_Sharma
    Cupcake Aug 3, 2019
    I bought this 3rd party adapter and only problem I'm facing is I have to turn 'otg storage' functionality ON every 10 minutes. Otherwise no audio is coming from the earphones.
    Saikrishna375 likes this.
  16. Ondrej Pokorny
    Eclair Aug 12, 2019
    Ondrej Pokorny , Aug 12, 2019 :
    I spent a lot of time Googling, and my conclusion so far is that OnePlus phones support passive audio adapters (the adapter connects the data + and - pins of the USB to the headphone jack and the phone drives the headphones like that), so there may be issue with some active adapters (they get the music digitally from the phone, the adapter contains a tiny soundcard that drives the headphones).
    martinjonsson01 and Shalin235 like this.
  17. RL89
    Cupcake Nov 6, 2019
    RL89 , Nov 6, 2019 :
    Same here!
    I bought the Apple USB-C to Headphone Jack, for my OnePlus 7T. At first, I thought it did'nt work, untill I pushed the volume on my phone up to 100%, but the volume op my earphones are about 60-70% indeed.
    Is this better with the original OnePlus USB C - 3.5 mm Jack? Or is it the same? Does anyone know?
    I think I will buy the OnePlus Type-C Bulltets earphones or one of the wireless earphones.
  18. Krzysztof_Halat
    Cupcake May 24, 2020
  19. megoshopping
    Gingerbread May 25, 2020
    megoshopping , May 25, 2020 :
    i ordered one for $8.99 from amazon that specifically states for oneplus 7 pro and it works fine. and if it has an issue, you can always return it.
  20. elanglois
    Lollipop May 25, 2020
    elanglois , via OnePlus 7 Pro , May 25, 2020 :
    There are two types. Once uses the DAC on the SoC and converts some of the pins of the USB to carry analog audio. The other has a DAC in the adapter and acts as a USB audio device. You'll needbto turn on USB OTG to have any chance of it working since it needs to power the DAC.
