2
USB C TYPE HEADPHONES
  1. G_plusone
    Marshmallow May 20, 2017
    G_plusone , May 20, 2017 :
    They can do that if they ship a type c earphone with it otherwise no go
    #41
    lostLambda likes this.
  2. lostLambda
    Lollipop May 20, 2017
    lostLambda , May 20, 2017 :
    An external DAC sounds like a great idea. It would probably be a much higher quality & feature rich than an in-phone DAC.
    #42
  3. Guillaume Vermandere
    Cupcake May 22, 2017
    #43
  4. vandijkerwin
    Cupcake Jun 7, 2017
    vandijkerwin , Jun 7, 2017 :
    Hi All,
    Any experiences with USB-C headphones?
    I used several Headphones and it worked fine for
    Music
    Whatsapp Calls
    However when I dial a number using the standad android caller app, the sound is really bad
    Sounds like I'm in a bathroom
    People can here themselves (no I don't put him on speaker)
    When dialing I hear a strange sound between the beeps. (looks like he's interfering with something else within in the phone)
    Any comparable experiences?
    #44
  5. marvels
    Donut Jun 20, 2017
    #45
  6. PAPZI1957
    Gingerbread Jul 12, 2017
    PAPZI1957 , Jul 12, 2017 :
    I bought an Xiaomi MI ANC USB C-Type earphone.
    It does not work, no sound comes through.
    I tried the sound source and the MIDI setting, but there was no result. Disable bounce control on or off.
    What setting should it work?
    Controls (volume, etc.) and noise filtering work, only the sound does not sound!
    Please help me!
    #46
  7. PAPZI1957
    Gingerbread Jul 13, 2017
    PAPZI1957 , Jul 13, 2017 :
    With USB Audio Player Pro app work this device.
    According to USB Host Check app, the USB Host is not enabled on the phone: android.hardware.usb.host.xml - OK, handheld_core_hardware.xml - USB host not enabled.
    Only the app mentioned above can bypass this problem.
    #47
  8. Jimmyto
    Cupcake Jul 29, 2017
    Jimmyto , Jul 29, 2017 :
    Turn on the OTG function in oneplus setting
    #48
    Themurtuza likes this.
  9. Baraldi
    Eclair Oct 3, 2017
    #49
  10. Themurtuza
    Jelly Bean Oct 21, 2017
    Themurtuza , Oct 21, 2017 :
    T
    Thank you , that worked perfectly for my oneplus5 .
    #50
  11. aashishvanand
    Eclair Oct 26, 2017
    #51
  12. ajshanker
    Ice Cream Sandwich Oct 26, 2017
    ajshanker , Oct 26, 2017 :
    I did not read all the replies but if no one else said, do try the new noise cancelling earphones from Mi that works on usb c. Personally I have used the le2 cdla headphones, they are way better than any ordinary headphones but that thing was so flimpsy I broke it through 3 months of use. The mi earphones are getting good reviews and going by their technology it is bound to be a great cheap alternative.
    #52
  13. ajshanker
    you should go into developer mode and activate use usb as audio source option.
    answer can be found in a detailed way somewhere here in the forum
    #53
  14. GiulioMecacci
    Eclair Oct 26, 2017
    GiulioMecacci , Oct 26, 2017 :
    feels like you are the only one with a brain, but how can you waste your valuable time like this? Thanks for that though
    #54
    elanglois likes this.
  15. elanglois
    Lollipop Oct 26, 2017
    elanglois , Oct 26, 2017 :
    1 ... If you are not a developer, stay out.
    2 ... Have you tried this successfully yourself? Or are you just telling people to mess with hidden settings without a valid reason
    3 ... The headphones are not a SOURCE of USB audio. They are the destination, called a SINK.
    #55
  16. elanglois
    I washed my Oneplus bullets in the washing machine with my clothes. They survived.
    #56
  17. ajshanker
    Ice Cream Sandwich Oct 27, 2017
    ajshanker , Oct 27, 2017 :
    wow, what a stupid argument " if you are a not a developer stay out". its there in the phone, there is no problem if you know how to use it. The method works, I tried it myself, and its given as "audio source" by android settings itself. Dont be a jerk going around mocking people.
    #57
  18. martinnius11
    Cupcake Oct 19, 2018
    #58
  19. F_Shah_Riam_Hossain_JJff
    Cupcake Sep 15, 2019
    F_Shah_Riam_Hossain_JJff , Sep 15, 2019 :
    I turned on the developer option on my 1+7 pro but how to "activate use usb as audio source option." ?
    #59
