Battery/Charging
USB charging not working for charge
  1. kuztardd Cupcake Mar 15, 2019
    kuztardd, Mar 15, 2019 :
    Not sure if the latest update caused issues, or its a fault on my phone?
    But i have just been trying to charge my One plus5 from a normal 5v charger.
    This would normally give me around >1000mA charge
    But I've tried a few chargers, and different cables and all i can get now is less than 200mA.
    BTW, My normal dash charger charges correctly
    Any suggestion on this fault?
    Would i need to do a reinstall on my phone? or could this be hardware?
    Thanks in advance
  2. Cervantes Lollipop Moderator Mar 15, 2019
    Cervantes, Mar 15, 2019 :
    The charge depends on the charger
    With the original charger works well, You do not have to worry
    buntycubal likes this.
  3. Spanakopitas Cupcake Mar 16, 2019
    Spanakopitas, Mar 16, 2019 :
    hmmm if before the update the charge was different maybe it is software, if it is a problem for you i would suggest reinstalling oxygen os. Hope this helps
  4. kuztardd Cupcake Mar 19, 2019
    kuztardd, Mar 19, 2019 :
    I used to get over 1000 mA from a generic non-dash charger, now I get around 200 mA. also data transfer has stopped working from my generic USB's. (so now if I have to charge my phone from an external battery it will take 5 times longer)
    So there is a definite fault.
    And I have just done a full installation and it hasn't corrected the problem. I am now guessing it is a hardware issue.. which sucks!
