OxygenOS USB connection to PC
  1. O1564045985787
    Cupcake Oct 8, 2021
    O1564045985787 , Oct 8, 2021 :
    Hello guys, just got my new OnePlus 9 Pro, i moved from note 20 ultra and had almost all oneplus phone that came out, somehow, my pc not detecting one plus at all , there is no even notification on the phone (pc show undetected USB device ) tried to restart, tried to open USB debug, adb seems to installed (I got the folder already at C drive ), what should I do ? thanks in advanced
  2. Shailender Sharma
    Nougat Oct 8, 2021
    Shailender Sharma , Oct 8, 2021 :
    In the device Settings search for USB Preferences, now manually enable the File Transfer toggle while connecting to a PC via USB cable. See if it works
    Caomhin and Aaron2017 like this.
  3. O1564045985787
    Cupcake Oct 8, 2021
    Shailender Sharma likes this.
  4. Shailender Sharma
    Nougat Oct 8, 2021
    Aaron2017 likes this.
  5. O1564045985787
    Cupcake Oct 8, 2021
  6. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Oct 8, 2021
  7. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 8, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Oct 8, 2021 :
    Tried a different cable, preferably a higher end cable? Or even a USB-A to C cable on a USB 2.0 port. The phone port can use 3.1 GEN1 speeds. Some have issues with the stock USB 2.0 charge cable. Usually just connection drops and such though.
  8. C1554234489781
    Cupcake Oct 17, 2021
    C1554234489781 , Oct 17, 2021 :
    I have OP6 and have same issues with USB not connecting to PC. Tried different cables and laptops. The phone was connecting to pc prior to update.
    This is a software issue . There seems to many users with same issues. One Plus owes its customers to fix this bug issue. I can't back up my phone to do a phone reset.
  9. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 17, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Oct 17, 2021 :
    Can't upload the backup to GDrive or something?
