Sound USB DAC not working
  1. dravidarch
    Donut Dec 15, 2017
    dravidarch , Dec 15, 2017 :
    Does the 5T support USB DAC's as I am not getting any sound through Dragonfly which I have connected using an OTG cable?
    G_Zak_Ali_FVdB likes this.
  2. zeez0neplus
    Cupcake Dec 16, 2017
    zeez0neplus , Dec 16, 2017 :
    I've got the same problem. I've read somewhere there is a driver to install but not been able to figure out what it is and how to install it.
    on other threads some are saying you may need to power the dac separately through a hub. which defeats the purpose in my mind
    let me know if you do find a solution
  3. Pratik2299
    Eclair Dec 16, 2017
    Pratik2299 , Dec 16, 2017 :
    open settings > advanced > other storage and enable it.
    let me know if your problem got solved
    kermex, lostLambda and G_Zak_Ali_FVdB like this.
  4. zeez0neplus
    it works !!!! thank you thank you.
    it caused my phone to slow and not push audio through. but a reboot quickly fixed it.
    the dragonfly defaults to blue - 48000hz
    Pratik2299 likes this.
  5. dravidarch
    Donut Dec 18, 2017
    dravidarch , Dec 18, 2017 :
    Yes it works once the OTG storage option is turned on in Advanced settings but it shuts off automatically after 10 min of inactivity which means one cannot listen to music for longer periods. WTF?!
    X1517396854503 likes this.
  6. zeez0neplus
    Cupcake Dec 18, 2017
  7. zeez0neplus
    zeez0neplus , Dec 18, 2017 :
    I had a look and it does state after 10mins of inactivity it will switch off. what music player are you using ?
  8. kyleruggles
    Cupcake Jul 27, 2018
    kyleruggles , Jul 27, 2018 :
    I tried the same on my 6, with a Fiio K1... nothing :(
    Any other suggestions?
    I've kinda given up trying to find solutions with this thing..
  9. LukaszMikolajczyk
    Donut Nov 16, 2018
  10. Warren Lord
    Cupcake Jan 2, 2019
    Warren Lord , Jan 2, 2019 :
    I have the same problem with Cyrus Soundkey on OnePlus 6, all battery saving options turned off, otg turned on, using usb audio player pro. did the factory reset as the OnePlus team advised and nothing
