USB Data Cable via OnePlus Nord 2
  1. J1630339706370
    Cupcake Oct 5, 2021
    J1630339706370 , via OnePlus Nord 2 , Oct 5, 2021 :
    The Cable that comes with the Nord 2 handset can transfer Data right?
    I think I was able to do it once but now whenever I plug it into my phone and laptop, the phone doesn't detect anything and simply starts charging again.
    I have kept USB debugging option ON, and even set the default USB preference to default.
    What is the issue? Please help
  2. Tokolozi
    Most Original Avatar Oct 5, 2021
  3. C1554234489781
    Cupcake Oct 17, 2021
    C1554234489781 , Oct 17, 2021 :
    I have the same issue . Other cables do not work either.
    OP need to find bug fix quickly.
  4. Tokolozi
    Most Original Avatar Oct 17, 2021
    Tokolozi , Oct 17, 2021 :
    Check if there's any dust buildup in your port. Do you get any chime from the PC when plugging it in?
    Shailender Sharma likes this.
  5. J1630339706370
    Cupcake Oct 18, 2021
  6. H1636734569737
    Cupcake Nov 12, 2021
    H1636734569737 , Nov 12, 2021 :
    Scroll down in "Network" part there is a something like "USB default settings". Ensure that "without data transfer" is not cheked like it was in my case.
    After I uncheck it my phone begin to ask me how do i wish to use plugged usb cable, for charging only or for transfer data?
  7. J1630339706370
    Cupcake Nov 16, 2021
    J1630339706370 , via OnePlus Nord 2 , Nov 16, 2021 :
    Yeah, we have kept the default USB configuration to "File Transfer"
