USB device not recignized
  1. harnoor992
    Donut Feb 6, 2015
    harnoor992 , Feb 6, 2015 :
    Earlier i try connecting the cable use to get mass storage and camera options and now nothing is displayed just the phone is getting charged. Can't transfer data from phone to desktop via usb :(
  2. Lunatasian
    KitKat Feb 6, 2015
    Lunatasian , Feb 6, 2015 :
    I had the same problem. I just tried another port and it worked. Have you tried that? Also, make sure that your phone screen is unlocked.
  3. dumitru_alina
    Cupcake Oct 23, 2015
    dumitru_alina , Oct 23, 2015 :
    i have a problem with my oneplus one...sorry for posting here but i can't open a topic
    My one+ dosent turn on if it s not conected to my laptop.
    it s charging fine at wall or laptop, but if it s not connected it keeps restarting, the only way i get to turn it on and get in the meniu is only if it s connected to my laptop. I ve entered in recovery,erase catche and reset to factory but the same problem... i can t use it if it s not connected to the laptop...donno what to do...any advice? i noticed that it s not opening for files transfers either...when i go and enable debugg it freeze and restarts over and over again
    Thank you..
  4. championspike
    Ice Cream Sandwich Oct 23, 2015
    championspike , Oct 23, 2015 :
    Do a ROM reinstall
  5. dumitru_alina
  6. championspike
    Search forums for that... And wats ur current rom?
    Tokolozi likes this.
  7. dumitru_alina
    Upgraded to cm 12.1, android 5.1.1
  8. championspike
    Need more details like cm12.1 is different from cos 12.1, so see which is it and get the build date which will be ur current is...
  9. dumitru_alina
    It is cyanogen os version 12.1-YOG4PAS2QL, Based version MPSS.DI.2.0.1.C7, Kernel version 3.4.67...conected to my laptop works fine but if i enable debugger it will freeze and restart...i can t find somenthing clear how to reinstal rom...It worked fine before the upgrade...
  10. championspike
    Try doing a factory reset in the recovery and see but don't wipe ur media that's ur main memory
  11. dumitru_alina
  12. Maspos
    Donut Oct 23, 2015
  13. dumitru_alina
    Cupcake Oct 24, 2015
    dumitru_alina , Oct 24, 2015 :
    I don t have a problem With the usb, the pproblem is without the usb. If it s not cine cred to the usb is keeps restarting, it works only and only on usb at laptop.
    Tried to reinstall ROM, tri ed with 2 versions but it says error in twrp because of the md5 file. But when i check the ROM în rom Checker it all goes green like it s okay. I don t realul know how or where is the md5 in the ROM zip so i could extract it... my phone is not rooted
  14. dumitru_alina
    I got it 3 days ago so i am not worried about the data.
    Can anyone please tell me how can i extract md5 so i can install the ROM?
    The ROM should be signed fasboot images or signedbeacon singer fasboot?
