2
USB NOT RECOGNIZED
  1. KRISHNAV biyani
    Cupcake Feb 27, 2018
    KRISHNAV biyani , Feb 27, 2018 :
    When connecting to PC (Windows and Mac both) the MTP mode is not starting it is only charging.
    No notification is coming in the notification drop down menu of whether USB is connected or not.
    Things Tried
    1. OEM UNLOCKING
    2. USB DEBUGGING
    3. SETTING DEFAULT AS FILE TRANSFER
    4. CLEAN FACTORY RESET.
    None of the methods worked.
    and phone is working very slow.
    both of the above problems is disturbing me from more than one year now. please help ASAP
  2. pa5t1s
    Marshmallow Feb 27, 2018
    pa5t1s , Feb 27, 2018 :
    Well, did you first check that your cable is 'Data' compatible, and not only 'Charge' enabled?
    Then, did you install the proper drivers when plugging your phone for the first time (on Win10)?
    Did you check that Windows properly recognize your 'Android Device' (in Device Manager)?
    OEM unlocking is useless in that problem...
    eye842 and Nick 59 like this.
  3. nicoenea
    Gingerbread Feb 28, 2018
  4. KRISHNAV biyani
    Cupcake Feb 28, 2018
  5. nicoenea
    nicoenea , Feb 28, 2018 :
    Sorry to hear that. I'd had the same exact problem and tried 3 different cables with no luck. Bought a new one and problem solved.
  6. KRISHNAV biyani
    Cupcake Mar 1, 2018
  7. Paschfire
    KitKat Mar 1, 2018
    Paschfire , Mar 1, 2018 :
    What is there to say?
    Did you check everything mentioned in the first comment? As those are the most common issues.
  8. F_Amit_Rawat_BDXu
    Cupcake Mar 1, 2018
  9. KRISHNAV biyani
    Cupcake Mar 2, 2018
    KRISHNAV biyani , Mar 2, 2018 :
    yes tried everything.. nothing's working. so was looking if there is any option rather than buying a new phone
  10. F_Manoj_Agarwal_cfBw
    Cupcake Mar 11, 2018
  11. Bilgewater Fandango
    Cupcake Mar 12, 2018
    Bilgewater Fandango , Mar 12, 2018 :
    My phone is dead at present. One option not discussed much here is that the USB plug and ribbon inside the phone have been shorted out somehow. I've purchased an internal USB port / ribbon cable for the phone, which I'm going to install as soon as the part arrives. If it works or it doesn't, I'll let folks know.
  12. KRISHNAV biyani
    Cupcake Mar 21, 2018
    KRISHNAV biyani , Mar 21, 2018 :
    sure. waiting for your reply
  13. Bilgewater Fandango
    Bilgewater Fandango , Mar 21, 2018 :
    I have installed the USB ribbon cable / port. So far, no sign the phone is either charging or willing to turn on, be recognized by my Windows laptop, or respond in any other way. Probably this phone is dead. But I've not quite given up yet. I've posted this video as a stand-alone, but here it is for your edification as well. Warning... it is not high tech in any way. In fact, I had a bit of fun with the whole thing.
  14. G_Jay_Khatri_ZMPJ
    Cupcake Oct 6, 2018
    G_Jay_Khatri_ZMPJ , Oct 6, 2018 :
    I got Solution its very simple
    what i did
    in Developer option > USB debugging ON
    turn off phone
    connect cabel
    turn ON phone
    woowwwww its work for me
  15. V1527956362437
    Donut Oct 6, 2018
    V1527956362437 , Oct 6, 2018 :
    same problem am also facing .. windows 7 was connecting but windows 10 was not connecting just charging only ..
  16. camila_racedo_lamanna
    Cupcake Mar 2, 2019
    camila_racedo_lamanna , Mar 2, 2019 :
    Hello, I have the same problem. have tried everything I have read on the forums.. still anything works... is it a problem of the windows 10 or the phone I'm still not clear about this.. . any iyher suggestions would be very helpful
  17. G_Sara_Wall_ZzGK
    Cupcake Mar 20, 2019
  18. lopemed
    Cupcake Oct 10, 2019 at 5:05 AM
