USB Port Issue via OnePlus 7T Glacier Blue
  1. #1
  2. camohan
    Nougat Moderator Jan 15, 2021
    camohan , Jan 15, 2021 :
    Hi there, have you tried checking if the UBS port has dust accumulated inside? Try using a non-metallic object like a toothpick and slowly remove the dust. Also, blow some air from the mouth to make it cleaner. Also, check the same thing for the UBS port of charging cable.
    Are you in an environment where there is a lot of dust or moisture?
    drl431 likes this.
  3. R@hulc97 , via OnePlus 7T Glacier Blue , Jan 15, 2021 :
    I used a toothpick to remove the dust. But there were no debris and dust were present in very nominal amount that should not hinder the charging process. I don't know what's the real issue! And I don't live in a very dusty environment.
  4. camohan
    Hi there, not really the right person but it's probably the paint or the metal part is getting eroded.. I guess taking the device to service centre could provide some more insight.
    More so if you are getting the warning message very frequently and often.
    R@hulc97 likes this.
  5. Bhaveee
    Honeycomb Jan 15, 2021
